LCE vs. Doug Thorley Headers 2.7
Discussion in 'Performance and Tuning' started by Col_Macklin, Sep 1, 2022.
  1. Sep 1, 2022 at 8:29 PM
    Col_Macklin
    Col_Macklin [OP] Well-Known Member
    2013 Murdered Taco/ ACAB 4wd 2.7L
  2. Sep 2, 2022 at 3:54 AM
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
  3. Sep 3, 2022 at 8:19 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  4. Sep 3, 2022 at 11:20 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I have run the LCE long tube/equal length header on my 2.7 when it was naturally aspirated and supercharged, and it definitely helped with drivability and low end torque. Also, iirc, the collector on the LCE is larger than the Doug Thorley, so there is a slight difference there. I think the LCE long tube header is a good upgrade for the money. I haven’t run the Doug Thorley header but I bet it’s an upgrade over the stock one. The primaries on the stock are small and seem like a restriction to me
  5. Sep 8, 2022 at 4:46 PM
    Col_Macklin
    I plunked down the coin for the LCE long tubes. Should be here in 2-3 weeks. I'm excited for this upgrade. This is my first long overdue HP upgrade since purchase. I'm ready to unleash the beast.
    Torspd and BassAckwards like this.
  6. Sep 8, 2022 at 5:35 PM
    BassAckwards
    Looking forward to hearing how you like it
  7. Sep 8, 2022 at 7:11 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Definitely curious to see as I have a 2.7
