lead-acid battery destroying body beneath it.
Discussion in '1st Gen. Tacomas (1995-2004)' started by JR_Roams, Jun 7, 2025.
  1. Jun 7, 2025 at 8:44 PM
    JR_Roams
    JR_Roams [OP] Well-Known Member
    2002 Tacoma TRD-OR EXC 5MT
    For those that use a lead-acid battery off-road on steep trails, how often do you restore the corroded mess left behind after the battery leaks and eats away the paint in the engine bay? I knew I should have just bought an optima battery. Now I need to restore my front driver side...wire brush all the rust and paint. Why did I listen to other posts saying lead-acid is fine? They just aren't really wheeling I guess.
  2. Jun 7, 2025 at 8:48 PM
    545 Well-Known Member
    2015 Access Cab
    Yeah, AGM is the way to go. But optima is not what they used to be
  3. Jun 7, 2025 at 8:52 PM
    JR_Roams
    I can run agm, but first gens can't charge it to where they need to be so it won't last as long for us. Even if optima isn't what they used to be they are probably still way better than your body melting away.
