Leading edge roof molding issue.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sidney Vicious, Nov 16, 2023.
  1. Nov 16, 2023 at 4:10 PM
    Sidney Vicious
    Sidney Vicious [OP] Well-Known Member
    NOLAUSA
    2013 Black DCSB Prerunner
    The leading / front edge of the roof molding on my Tacoma is coming up. The first inch and a half or so.
    I am to blame because I removed the original for a roof rack. I have removed the rack and now want to go back to the molding. I used Gorilla Double Sided tape but the front is acting up.
    This is not rocket science I don't think.
    What is a fixit and forget it solution?
    Thanks.
  2. Nov 16, 2023 at 5:41 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    What ever they use to glue the windshield in has been holding mine down for about 10 years now.
    The guy at safelite glued it back down for me when he put a windshield in my truck.
    I've been through carwashes and everything. So far, so good.
    Sidney Vicious[OP] likes this.
  3. Nov 16, 2023 at 7:00 PM
    Sidney Vicious
    NOLAUSA
    There IS a small chip in my windshield…
    TnShooter likes this.
  4. Nov 16, 2023 at 7:12 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    New moulding, yours might have shrunk.
  5. Nov 16, 2023 at 7:43 PM
    Sidney Vicious
    NOLAUSA
    This is new OEM.
  6. Nov 16, 2023 at 8:00 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Might need to pull it up and re-lay it in the ditch favoring the front a hair more. It doesn’t install with any glue or tape that I could see when I installed my rack. Just some metal that engages it at the front/back and the fins that press into the ditch channels.
  7. Nov 16, 2023 at 9:55 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Front of the molding has a ridge built in it that has to click into the metal roof mounted holder that has a slot in it. As above you may be off on location as front should have been installed first and you need to feel that ridge click into the slot. If all else fails shot some black silicon seal in to hold it down and tape/weight it down for several hours to ensure it sets. If your molding is bent up in the front some heat applied may help it lay down to install.
