Leaf Blower Heaven....
Discussion in 'Off-Topic Discussion' started by monoman, Feb 9, 2009.
  1. Feb 9, 2009 at 11:09 AM
    monoman
    monoman [OP] Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    :mad:So I go to start my little Homelite leaf blower yesterday & the thing starts up (barely) but has very little power. Then, it starts to make popping sounds, so I'm thinking it's toast. I can't complain, a friend gave it to me a few years ago & it's been working fine, but I guess it's seen better days. Do you guys know much about these hand held blowers? I'll probably have to get a new one so any recomendations out there? I'd like to get the same type (hand held gas type). I also don't want to spend too much, like maybe under $150?
    Thanks guys.....:D
  2. Feb 9, 2009 at 11:21 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Get a bagpack one... it's sooo much nicer... :D
  3. Feb 9, 2009 at 12:55 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
  4. Feb 9, 2009 at 12:58 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Put a new plug in the blower... it may something that simple!
  5. Feb 10, 2009 at 10:50 AM
    monoman
    Dave
    Tried that, didn't work. I'd like to get one of those backpack types, but I'm not spending over $200 for one. I mainly use it for leaves or after mowing the lawn. Oh well, have to do some looking around, thanks for the input guys!:D
  6. Feb 10, 2009 at 11:12 AM
    Sandfire
    Sandfire Well-Known Member
    southwest midwest
    06 TRD Sport DC 4x4 silver
    OME 885 springs with OME N140s shocks, Total Chaos UCA's, TSB AAL, OME N182's, MT BAHA ATZ 4ribs.
    I used to have a mowing business, so maybe I can give you some helpfull advice.
    Some of the smaller handheld ones you can find for about that price are made by echo, stihl, and shindaiwa. These are all great brands that will outlast the little walmart junkers by years.
    You may be able to find some used back pack models on craigslist or ebay for that price. My personal faverite is the shindaiwa.
  7. Feb 10, 2009 at 11:22 AM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    I actually repair small engines on the side. Unfortunately, Homelites are pieces of shit and once they go, its rare that they can be repaired and still work that great. The best are Shindaiwas. But Echo makes a really good blower too and they cost less. We've had an Echo for 12 years and the thing still starts and runs great.
    But... before you buy a new one, it sounds to me like you have a faulty carb diaphragm or perhaps a clogged spark arrestor. Some that were sold for the California market have a screen over the exhaust hole. You can remove it with two screws. If it is dirty, clean it. Secondly, the little carbs on these use a diaphagm. Sometimes they get pin holes which will cause the carb not to generate enough vacuum to draw gas. Or it will flood the engine. They're heald together with 4 little screws on the top. Take a look ( carefully) and see what it looks like. It could also be the primer bulb. Some will dry rot and crack. That too can cause problems. Also check the air filter and spark plug. 2 cycle engines love to clog up air filters and spark plugs.
    Let me know how it goes.
  8. Feb 10, 2009 at 2:45 PM
    monoman
    Dave
    I used to do yard maintanence too (back in the 80's & 90's) & loved the Echo PB 400E. Very well built. Those things outlasted anything by far. Sure don't make 'em like that anymore! I have a Shindaiwa hedge trimmer & that thing kicks ass! Sure beats those cheap electric ones. Anyway, I went ahead & took the blower apart & found that it had a scratched cylinder. I do know that once those things get like that, it's toast. I't's not worth it to fix. I hope I have the right oil/fuel mixture. I'm using 40:1 like it says on the blower.....:confused:
  9. Feb 10, 2009 at 2:50 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    rebuild it, and make it more powerful! if not you can always mail it to chris4x4..lol
  10. Feb 10, 2009 at 2:53 PM
    monoman
    Dave
    There ya go! I could put a turbo on it? :eek:
    Oh shit, I'm sounding like Tim, "The Tool Man" Taylor now......:D
  11. Feb 10, 2009 at 2:55 PM
    Bakemono
    Bakemono Wrath of the runbird
    Southern Wisconsin, USA
    '09 Toyota Tacoma regular cab 4x2
    Buy an Echo. Best brand of handheald power equipment there is. Ive got an Echo handhelds leafblower and its awesome.
    I run it wide-open all the time and it just keeps going and going with no problems. Ive also got a 50cc Echo chainsaw and its beast.
    You cant go wrong with an Echo, IMO.
    Stihl and Husqvarna are nice too. Personally, I wouldnt buy anything but an Echo, Stihl or Husqvarna. Poulan/Craftsman and Homelites are junk.
  12. Feb 10, 2009 at 2:57 PM
    Bakemono
    Most likely what happened is that the piston ring broke and part of it got wedged between the piston and the cylinder wall, causing the scratch. It happens sometimes.
    Just go down to your local Home Depot and buy an Echo.
  13. Feb 10, 2009 at 2:58 PM
    monoman
    Dave
    Which model Echo handheld do you have? I'll probably get something like that......
  14. Feb 10, 2009 at 3:01 PM
    monoman
    Dave
    Yea, I'm sure thats what happend. It happens alot with these 2 stroke motors.
    I'll have to check out Home Depot later, thanks guys!
