Leaf pack differences?
Discussion in 'All-Pro Off Road' started by MyToyTaco, Sep 30, 2009.
  1. Sep 30, 2009 at 7:24 PM
    MyToyTaco
    MyToyTaco [OP] ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    I have the factory non-tsb leafs, with an AAL right now. I'm starting to get annoyed at the stiffness. They seem really bumpy to me. I've also got an axle wrap issue that I haven't been able to remedy. And the squeak.. f*ck! everytime i drive off pavement my shit sounds like metal grinding metal, regardless of cleaning & lube. driving me nuts.
    Bottom line, I'm looking at full leaf packs to start fresh.
    I've read good things about all pro, and im not loking to spend $600 on some springs. I know that these aren't designed to handle weight...but I'm wondering - is there any difference in weight capacity between the 1.5" and the 3"? Or any difference in ride stiffness?
  2. Sep 30, 2009 at 7:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Check out Wheelers. They carry Deaver, and Alcan. Top line springs IMHO. :)
  3. Sep 30, 2009 at 7:29 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    should handle the same weight. just an FYI, i got the wrap w/ the 3" springs and no matter what, all springs wll squeak...
  4. Sep 30, 2009 at 7:33 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    But you shouldn't have to put up with it. If this is the case go to a spring shop and have new teflon pads installed. It cost me around $50 to do my Tahoe and it was money well spent.
  5. Sep 30, 2009 at 7:37 PM
    MyToyTaco
    MyToyTaco [OP] ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    I saw you post that in another thread I read..thought about doing that too but i really want a smoother ride so i think im going to leave them alone for now and hope new packs will last a while w/o the noise..
  6. Sep 30, 2009 at 7:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    But the squeak can be eliminated. :)
  7. Oct 1, 2009 at 7:10 AM
    jhodge83
    SC
    17 XLT Sport
    i know...just stating that at some point, all will squeak
  8. Oct 1, 2009 at 7:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeeee ep! :)
  9. Oct 1, 2009 at 8:35 AM
    MyToyTaco
    MyToyTaco [OP] ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    :rolleyes:
  10. Oct 1, 2009 at 8:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :confused:
  11. Oct 1, 2009 at 8:40 AM
    MyToyTaco
    MyToyTaco [OP] ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    deaver & alcan = both about $599. Is there really THAT much of a difference to be able to charge $200+ more than all pro?
  12. Oct 1, 2009 at 8:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok....I didnt know thats what they were chargeing. Last time I looked into them, they were much less.
  13. Oct 1, 2009 at 8:45 AM
    MyToyTaco
    MyToyTaco [OP] ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    they are.. but really though, IYHO, is there a big difference in the springs? If it's significant, i would possible consider spending $200 more..
  14. Oct 1, 2009 at 8:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have never heard anything bad about the Devers or Alcan. I know Deaver has TOP notch customer service. They are a leaf spring...nothing really high tech about them, so I dont see how one could be that much better than another. Jhodge swwms pretty happy with his AllPro springs, so it hay be worth saveing a few bucks. To Add: You MAY want to give Wheelers a chance to match the price of the all pro springs.
  15. Oct 1, 2009 at 3:51 PM
    allpro
    allpro Well-Known Member
    Montana
    All Kinds Of Toyotas!!!
    Our springs are less expensive only because we buy them hundreds at a time, and we can pass that quantity discount on to our customers. They also carry a 1 year warranty against manufacturer's defects!
    Also, to answer your question, the spring rate is the same on the 1.5" and 3" leaf springs. Thanks!
  16. Oct 2, 2009 at 1:53 AM
    nolanspawn
    nolanspawn Work In Progress
    Layton, Utah
    2011 Tundra Crewmax
    Corsa Exhuast, AFE Intake
    Will the leaf springs from either AllPro, Deaver or Alcan give a weight capacity improvement over stock? I am thinking about going the full leaf pack instead of AAL before I get started. Been waiting on my Icon setup with an AAL but starting to think I should just snag a pack.
  17. Oct 2, 2009 at 1:59 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    No, they will not. You will actually loose carrying capacity by a significant amount, although, this is the price you pay for articulation and increased off-road/on-road ride.
  18. Oct 2, 2009 at 6:46 AM
    jhodge83
    SC
    17 XLT Sport
    none of those will improve capacity, but from stories i've heard, the deavers/alcans will hold weigt better than the AP's
  19. Oct 2, 2009 at 11:27 AM
    allpro
    Montana
    Our springs were designed for flexing off-road, but they will handle some weight as well. I've personally carried 500 lb loads several times and towed 5,000 lb trailer & boat with no issues. The truck will sit lower in the rear until the load is removed, but then they return to their normal height.
  20. Oct 2, 2009 at 8:28 PM
    SiRMarlon
    SiRMarlon The Photo Ninja!
    Marlon
    Los Angeles
    Canon 5D MarkIII
    Hit my brother up Nick...we are rocking the 3" AP leaf pack in the rear of the truck! The ride is definitely smoother and now that the new Fox Shox's are going on the rear it's going to be even more smoother! If you are worried about sag, get some Timbren bump stops to go along with them. I believe AP also sells the Timbrens with there U-bolt flip kit! The Timbrens will help keep the truck from completely sagging...
    It looks like this...
