Leaf pack help
Discussion in '5 Lug' started by Skinny Rogers, Mar 15, 2013.
  1. Mar 15, 2013 at 3:29 PM
    Skinny Rogers
    Skinny Rogers [OP] U know fish can hear u thinking just b4 u sneeze
    Lance
    NC
    10 taco
    Looking for leaf pack options to go with fat bobs. Wanna replace full pack not add a leaf. Any suggestions?
  2. Mar 16, 2013 at 12:47 AM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    all pro standards seem to be very popular but theres lots of options. why do you want to upgrade the whole pack?
  3. Mar 16, 2013 at 6:31 AM
    Skinny Rogers
    Lance
    NC
    10 taco
    I have read on the site ppl talking about sagging in the rear and I am not a fan of that look so I assumed replacing the whole pack could hopefully help me eliminate that. Maybe I'm wrong. Never had a 5 lug tacoma before.
  4. Mar 16, 2013 at 9:12 AM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    What do you plan on using your truck for mainly?
  5. Mar 16, 2013 at 9:21 AM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    5-lugs are Spring under correct? If so all pro will not work.
  6. Mar 16, 2013 at 10:01 AM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    And why is that?
  7. Mar 16, 2013 at 12:33 PM
    Skinny Rogers
    Lance
    NC
    10 taco
    It is spring under. Mainly used for hauling and pulling occasionally. Nothing terrible but I'm not a fan of sagging rear. Don't like the look.
  8. Mar 16, 2013 at 3:24 PM
    nfs257
    DFW
    She gone
    If I understood it right the arch isn't enough for spring under and they were made for spring over meaning he would have to relocate his spring perches.
  9. Mar 16, 2013 at 6:50 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    no. the 5 lug and 6 lug leafs are the same eye to eye measurements. so lets say you put a 3" leaf pack for soa on a sua truck it will only give you roughly 1.5". they will work just wont yield as much lift. you only have to move perches when your changing to lt or leafs that are longer than stock eye to eye or center pin to eye in either direction etc...
  10. Mar 16, 2013 at 6:53 PM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    I've heard good things about ... nothing fancy, beefy though, decent price
  11. Mar 16, 2013 at 6:53 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    only thing that would help you would be the all pro expos but those will rough up the ride if its empty. if you dont plan on towing or hauling on a daily basis the aal will serve you fine for ride height. other thing you could do is add helper springs or air bags
  12. Mar 16, 2013 at 7:47 PM
    nfs257
    DFW
    She gone
    :bowdown:
  13. Mar 16, 2013 at 7:55 PM
    Skinny Rogers
    Lance
    NC
    10 taco
    Any way to get more lift with a leaf pack. More than 1.5?
  14. Mar 16, 2013 at 9:03 PM
    Buckoma
    Buckeye, AZ
    2016 TRD Sport 4x4
    Icon or Deaver make leaf packs that prvide more lift but they generally suck when it comes to heavier hauling or towing.
  15. Mar 16, 2013 at 10:32 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    :humble:icon doesnt make leafs :p but you can look into a pack that like 5" to get more lift
  16. Mar 16, 2013 at 10:34 PM
    Razgriz
    Razgriz wtf am i reading
    San Jose, CA
    2013 White TRD 4x4
    icon rebrands. or they were going too. Never saw if they started selling.
  17. Mar 16, 2013 at 10:34 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    my suggestion would be the 2" aal that you can get from fat bobs and add the airbags. leafs that add that much lift are generally flexy so they wont be ideal for towing or heavy weight
  18. Mar 17, 2013 at 8:53 AM
    Skinny Rogers
    Lance
    NC
    10 taco
    Ok that's good to know. What was that about 5" of lift with a pack?
  19. Mar 18, 2013 at 11:09 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Yes, from the eye to eye, both 6 lug and 5 lug are similar (close to ~62").
    Just because they are similar eye to eye, the 6 lug leaf packs will not give a 5 lug any lift. It will do the opposite, you will actually drop the rear a few inches.
    The pic below has a Deavers J66 (10 pack) installed on the rear of my 5 lug. If you look at Deavers site, it says a TACOMA PreRunner 1.5" lift in the rear.
    The reason why it does not work is the arch of the springs, the 4x4/PreRunners are SOA, so the arch is not as steep as the 5luggers.
    One way to get more lift for a 5 lug is custom packs from Deavers, you will have to call them and let them know you are not a 6 lug and you are looking for a 1.5" lift. They can also make the leaf spring to be stiff for towing, or just a soft pack for a 'smooth' ride in the rear.
    The other option to raise the rear on a 5 lug is to purchase an AAL from anywhere. IMO, purchase a long AAL. Fat Bob's kit allows you to to purchase a long or short AAL.
    There is also a third option, this option would take some cutting and welding, but you could do a complete conversion. Turn your 5lug SUA to SOA.
  20. Mar 19, 2013 at 12:25 AM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    The arc difference is roughly 1.5" thats why i said a 3" pack would give 1.5 5" would give 3.5 etc. id look into having your deavers reworked for more lift
