Leaf pack or Add a Leaf with TRD Pro Westcott Designs lift kit
Discussion in 'Suspension' started by dave5623, Jan 12, 2021.
  1. Jan 12, 2021 at 8:15 AM
    dave5623
    dave5623 [OP] Well-Known Member
    2020 TRD Pro
    I ordered the Westcott Designs front lift kit for my TRD Pro. I'm currently trying to decide what to do for the rear. It seems people don't like the stock leaf pack so I'm wondering if the better route to take is replace the whole leaf pack (and if so which leaf pack to go with) or just go with an add a leaf (and if so which add a leaf to go with).
    It seems like the labor involved with replacing the entire leaf pack isnt that much more effort then adding a leaf so for the added cost it might be worth just replacing it entirely .
  2. Feb 2, 2021 at 9:36 AM
    2020 PRO
    2020 PRO Active Member
    2020 TACOMA PRO
    Im looking to do the same with my truck any info on this is greatly appreciated.
  3. Feb 2, 2021 at 8:44 PM
    galito
    galito Well-Known Member
    Edgardo
    Army Green TRD Pro 2020
    Looking to do the same. I’m trying to replace the block it came with.
  4. Mar 16, 2021 at 5:24 PM
    2020 PRO
    2020 TACOMA PRO
  5. Mar 17, 2021 at 9:35 AM
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    Same looking for info for the rear westcott spacer / aal . But I have a 200 lbs cap
  6. Mar 17, 2021 at 11:16 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I went with a full leaf pack (OME Dakar medium) because I wanted to increase the ride height without increasing the spring rate. Since I’ve never seen spring rate information published for leaf springs (possibly because it’s not as simple as a single number), I’m not entirely sure I accomplished the goal, however qualitatively it doesn’t seem too stiff post installation.
    Island Cruiser likes this.
  7. Mar 17, 2021 at 12:30 PM
    2020 PRO
    2020 TACOMA PRO
    If one were to just add a leaf to the rear to get the truck to be level with the Westcott designs up front Is there a certain one that someone with first hand knowledge can recommend ? I would think to add a leaf would be the way to go to keep the system as close to stock as possible.
    galito likes this.
  8. Mar 17, 2021 at 12:45 PM
    gudujarlson
    Minnesota
    It depends on what you mean by “close to stock”. With an AAL you are keeping the stock leaves, but you are changing the spring rate and thus also the ride height. With a full leaf pack you are (with the correct leaf pack) maintaining the spring rate while increasing the ride height. Either way you look at it, you are not stock anymore.
  9. Mar 17, 2021 at 1:36 PM
    2020 PRO
    2020 TACOMA PRO
    So then which is the better way to go ?
    add a leaf or replace the whole Leaf pack to acquire the desired height.....
  10. Mar 17, 2021 at 2:12 PM
    gudujarlson
    Minnesota
    That depends on your goals.
  11. Mar 17, 2021 at 2:23 PM
    2020 PRO
    2020 TACOMA PRO
    Goals..... higher than the stock Pro with minimal change to the ride quality
  12. Mar 17, 2021 at 2:29 PM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    If you want similar/same ride quality and a lift, your best option would be to swap the leaf pack. doing an AAL will change the spring rate, payload, hauling cap, and thus the ride quality.
  13. Mar 17, 2021 at 2:30 PM
    gudujarlson
    Minnesota
    I’m guessing you would prefer a full leaf pack then. It will increase the ride height by having a deeper arch rather than by being stiffer. Note that I think most (all) full leaf packs are designed to lift 2+”.
  14. Mar 17, 2021 at 3:09 PM
    2020 PRO
    2020 TACOMA PRO
    Ok thats good info as i dont have any experience with any of this..... is there a certain Leaf pack that you would recommend or that you know of that others have used and have had good success with the Westcott kit ?
    Thanks
    gudujarlson
  15. Mar 17, 2021 at 3:27 PM
    TacoTyusday
    Zac
    San Diego
    icon rxt option 1, deaver j66, OME Light duty are gonna be the popular ones
    Rough country, ironman 4x4, general spring and a few other companies also make leaf spring packs, but aren't nearly as popular on this forum. Whether that's because of false sense of superiority, quality issues, price, or whatever else, IDK.
    galito likes this.
  16. Mar 17, 2021 at 3:34 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I initially added a progressive aal,which is like a mini leaf pack that is added to the stock leaf pack. Mine was from icon but wheelers sells the same thing for a little cheaper. I kept the over load spring in which gave me a 1.5” lift. Keeping the overload out would give you .5 less height and level the truck.
    I switched that up took out the progressive aal and stock pack and switched to a icon rxt leaf pack set at option 1. That gave me 1.5” lift in back. After adding the wescott kit I’ll probably switch to option 2 on the pack which will give me 2”....hope this helps
    galito likes this.
  17. Mar 17, 2021 at 4:42 PM
    2020 PRO
    2020 TACOMA PRO
    Yes ! Big help..... thank you for all the replies it is much appreciated.
    JuanitoBonito[QUOTED] likes this.
  18. Mar 17, 2021 at 5:07 PM
    79CHKCHK
    79CHKCHK Padawan of Rock Lobster
    SoCal no mo
    2018 Super White TRD Pro AT
    I have a 2018 Pro and needed something to go with a 1.5" lift in the front. I decided I would fab my own AAL using a stock leaf pack from a low mileage 2019 Pro. Used to see this all the time in the Jeep XJ world, known as the bastard pack or franken-pack. I used the main leafs, cut off the bushings to length, drilled holes for the stock leaf pads, and installed them as the 3rd leaf. Kept all the other stock leafs, including the overload. I got a about 1" of lift in the rear for a total of .75" of rake. I have an ARE CX-HD with internal frame and HD load bars, aluminum windoors, and driver side toolbox loaded with recovery gear. In total, probably 275-300 lbs.
    I definitely like the ride better. It is similar to stock but a little more sure footed and less body roll. I had a helluva time drilling through spring steel, used two 1/2" drill bits . This isn't for everyone, but I enjoy tinkering and experimenting a bit. Haven't seen another 3rd Gen with a bastard pack, so I gave it a shot. I still have to put my decked drawers and tools back in, hoping I still have some rake. If not I'll get to work on another set of leafs to add.
    2020 PRO likes this.
  19. May 11, 2022 at 8:34 PM
    PearBear
    PearBear Active Member
    Dylan
    2020 Tacoma TRD Pro
    Full skid plate collection from Cali Raised, Rock Sliders, Overhead Bed Rack, RTT, Decked System, Ditch Lights
    Hey... just joined. This post prompted me to do it lol. I'm in the same boat as you. Just ordered the Westcott Fox 2.5 lift for the front and the rear. Now I'm still figuring out if I go with AAL or OME heavy leaf pack. I've got about 500 pounds on the back end of it right now, with another 300 to go. I've been racking my brain on how much its sagging now vs. what just the OME heavy leafs will do vs. the leafs + the westcott 1 inch-inch-more-on-the-back vs. what its going to be like after adding more weight. ffs.... someone tell me what to do :p
  20. May 11, 2022 at 8:38 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    ICON RXT leaf pack or Deaver leaf pack.
    OME will sag and squeak.
    AAL is a bandaid, but works.
