Leaf Pack or Air Bags
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GreatCanadian, Jan 26, 2015.
  1. Jan 27, 2015 at 7:38 AM
    #41
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    Cradles are only for lifted trucks, so as to make maximum use of the lift when on full droop. If all you plan on is adding bags to an otherwise stock truck, you don't need cradles. If you plan on lifting, and want to maximize rear suspension travel, then you need cradles.
    From what it sounds like, you don't need cradles.
  2. Jan 27, 2015 at 6:29 PM
    #42
    Pigpen
    Dan
    Northwest Montana
    The cradles keep you from damaging the bags when you flex too far. If the bags have much pressure in them (I think the suggested max is 20psi for unweighting) and you flex, or put the truck on a mechanics lift, they can be damaged. On stock suspension I have flexed mine way off the cradles many times. without the weight of the axle pulling on the bag, you can comfortably run much higher psi and flex all you want.
  3. Jan 27, 2015 at 8:06 PM
    #43
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
  4. Jan 28, 2015 at 11:20 AM
    #44
    GreatCanadian
    GreatCanadian [OP] Well-Known Member
    Newfoundland
    SR5 4X4 V6
    So where is a good dealer online in Canada (or on TacomaWorld) to buy these things - either leafpack, airbags, or Timbren bumpstops? Can't find much online in Canada, but I'm sure you folks know more than me about this stuff.
    GC
  5. Jan 28, 2015 at 1:10 PM
    #45
    darkfader
    darkfader Will this fit without rubbing?
    Josh
    West Virginia
    2018 DCSB6MTFTMFW
    Not sure about Canada, but the cheapest price I have found on the airbags, other than buying used, is sd truck springs dot com. I'm unable to post the link and I don't know if they offer free shipping to Canada or not.
  6. Jan 28, 2015 at 1:14 PM
    #46
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
  7. Jan 28, 2015 at 1:19 PM
    #47
    darkfader
    Josh
    West Virginia
    2018 DCSB6MTFTMFW
    Yea sorry, I edited above, but take a look at sd truck springs dot com. 319$ shipped in the states, not sure about Canada though.
  8. Apr 27, 2015 at 2:31 AM
    #48
    DrFunker
    DrFunker Well-Known Member
    neverstuck - How are the bumps holding up?
  9. Apr 27, 2015 at 7:24 AM
    #49
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    Have you seen my update on that thread? Post #63
    No sign of wear or tear on them. My only complaint right now is the shocks aren't dampening as they should over bumps. They feel more jittery than they should but still much better than expected and I can't blame the Timbrens for the shocks being weak.
  10. Apr 27, 2015 at 9:04 AM
    #50
    DanceswithWolves
    DanceswithWolves palabra a tu madre
    Jerry
    Roosevelt UT
    13 DCSB OR
    I need some help with AAL selection. I put a Leer XQ on the truck 6 months ago. The rears springs have finally settled down. With the bed empty and 1/2 a tank the truck sits level and it's stays off the bump stops. A full tank, 4 people and a couple of hundred pounds is a different story. I also put on a set of Hankook LTs which amplify the issue.
    I want to put on AALs for the time being. I'm thrifty(cheap) and don't use credit cards for upgrades. I bought the truck in 7/14, put the shell on 11/14 and tires 2/15, so discretionary spending is thin now. I'm at 36K on the truck now and want to put off suspension upgrades until next spring. So my question is what AAL should I be looking at to get level at load? Timbrens a better option? I don't really want to go with bags.
  11. Apr 27, 2015 at 9:18 AM
    #51
    neverstuck
    Guido
    Lebanon
    13 DCLB sport
    Timbrens will not be garbage when you get a proper suspension upgrade so that's a plus but they aren't intended to level you off to compensate for a full tank of gas. Your leafs really suck that bad?
    Have you had the tsb 4th leaf installed? Do that first.
  12. Apr 27, 2015 at 9:18 AM
    #52
    DrFunker
    :popcorn:
  13. Apr 27, 2015 at 11:29 AM
    #53
    DanceswithWolves
    Jerry
    Roosevelt UT
    13 DCSB OR
    No TSB for me, '13 DCSB OR. Not too worried about the bro lean, just the frequency of hitting the bumpstops. I plan on going OME coils up front with Dakars in the rear next year. Undecided about shocks. I don't want helwig helpers since I wouldn't be using them after upgrades. bags, dunno. I think I'll go with Timbrens since I can still use them after upgrades.
    Do the Sport 4 leafs offer better load capacity? If so, I should keep my eyes open for a used set popping up for sale.
  14. Apr 27, 2015 at 12:14 PM
    #54
    DanceswithWolves
    Jerry
    Roosevelt UT
    13 DCSB OR
    Yeah. Dakars . Doing research on Timbrens now. My goal is to push upgrades out 1 year and do what I need for now. Next year is full suspension build out, front bumper and PrinSu rack. 1-2 years is spacers and Hankook Dynapro LT285/70/16 ( I love my LT265/7-/16).
    My truck will be sorta Beavis/OZ-T, ewwww
  15. Apr 27, 2015 at 12:51 PM
    #55
    DanceswithWolves
    Jerry
    Roosevelt UT
    13 DCSB OR
    Timbrens in the rear for now. twin short women with flat heads( no jokes) if they need help.
    Old School likes this.
