LEAF PACK QUESTION???
Discussion in 'Suspension' started by PETEREDGE, Jan 19, 2015.
  1. Jan 19, 2015 at 2:49 PM
    PETEREDGE
    PETEREDGE [OP] Well-Known Member
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    ARB FRONT BUMPER...16x8 SR8 RIMS ,YOKAHAMA MT'S,DEMELLO SLIDERS,UPGRADED SOUND SYSTEM...
    I have a 2012 Baja Edition i just added a 2" AAL and the Toytec 1" lift in the front.Now my rear sits way to high and i was wondering if i can take out the overload leaf from the factory pack and leave the AAL in??Has anyone done this??
  2. Jan 19, 2015 at 3:53 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    That can certainly be done. And I know that some have with good results.
  3. Jan 19, 2015 at 3:56 PM
    PETEREDGE
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    Thats good to hear...
  4. Jan 19, 2015 at 3:58 PM
    ObiWan Tacomi
    ObiWan Tacomi Well-Known Member
    Joe
    NYC
    '13 DCSB Tacoma TRD OffRoad
    Airaid Intake Magnaflow Exhaust Icon Coil Overs (ride quality is amazing) Icon AAL Icon Rear Resi's BruteForce Hybrid Front Bumper Ghost Raptor Grille Raptor Lights Debadged
    I have the Icon AAL and the 2.0 resi shocks in the rear...
    Icon actually recommends you remove the overload spring if I recall correctly.
  5. Jan 19, 2015 at 4:16 PM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    There's additional steel there to support the deletion of the overload with the Icons, approximately 3/4" with the 3 stack. A single AAL measures about 1/4" so there less steel there to help support the existing factory leafs when pressure is applied over the axle perch.
    Honestly if I had a single AAL I would not remove the overload simply because you will be expecting too much out of the leafs on up travel. As it is the factory packs sag out quite fast, removing the overload will just accelerate this.
  6. Jan 19, 2015 at 4:16 PM
    PETEREDGE
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    I remember asking the guy at YOTAMASTERS when i bought the AAL and he didnt mention anything,about removing and other leafs?
  7. Jan 19, 2015 at 4:47 PM
    PETEREDGE
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    So then do u think taking the AAL out and going with a 1" block would be better.
  8. Jan 19, 2015 at 4:53 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    If it's new, give it a month or about 1000 miles to settle.
    If you need to get a load of mulch or something for your home. That'll help it settle faster.
    You might be ok with how it sits after it's had some time to wear off the newness.
    Unless AAL don't settle the way full leaf packs do but I'm sure someone will point it out if that's the case.
  9. Jan 19, 2015 at 5:01 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X100000000
  10. Jan 19, 2015 at 5:49 PM
    PETEREDGE
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    I'll give it alittle more time to see how it loks.
  11. Jan 20, 2015 at 9:23 AM
    icon_rep
    icon_rep ICON Vehicle Dynamics Vendor
    Riverside, CA
  12. Jan 23, 2015 at 3:16 PM
    Mr Salty
    Hermmy
    Lots of chrome
    Mr. Icon he has a single AAL, your instructions are for your 3 leaf mini packs even though the process is essentially the same. He wants to know is its a good idea to ditch the overload with the single AAL. Some say go for it I say its not the best approach due to the lack of steel, but that just me.
  13. Jan 23, 2015 at 3:19 PM
    icon_rep
    Riverside, CA
    Understood, which is why I highlighted 3 leaf in the post. I was just throwing the link up so he could understand how ours worked is all.
  14. Jan 23, 2015 at 3:25 PM
    Mr Salty
    Hermmy
    Lots of chrome
    So your thoughts....... ditch the overload or keep it in and let settle
  15. Jan 23, 2015 at 3:35 PM
    icon_rep
    Riverside, CA
    If there is no weight going in the bed at all, my guess is it would likely work out fine being the AAL is 1/4" thick. That is a pretty stout leaf. I bet it is pretty stiff right now outside the height issue he is wanting to adjust.
    OP what does it ride like now with the overload in?
  16. Jan 23, 2015 at 5:12 PM
    PETEREDGE
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    It dosent ride bad at all its just to rear high.
  17. Jan 23, 2015 at 5:27 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yes you can pull the overload, on 2nd gens its about 3/4" thick at the perch & 1st gens are about an inch...
  18. Jan 23, 2015 at 8:05 PM
    icon_rep
    Riverside, CA
    Well it will get a little softer from where you are at so keep that in mind, but heck give it a whirl. You can always put it back if you don't like it at the cost of a center pin and a little labor.
