Leaf recall even with aal?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by h22dx, Oct 21, 2014.
  1. Oct 27, 2014 at 6:54 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    How do you know that? When I plug the VIN for my '11 DCSB into http://touch.toyota.com/recall all I get is the stupid tire sticker recall which doesn't even apply to my truck. I already had the four leaf TSB done but, given how they handled the sticker recall, I doubt Toyota is organized enough to know it was done.
  2. Oct 27, 2014 at 7:03 PM
    farooked
    farooked Out the rack and on the road!
    Svens Dad
    US Western
    Tacoma 4x4
    6" ProComp suspension lift, 34" Offroads, thottle body spacer, cai
    Void if lifted? ITs gotta break before they switch it?
  3. Oct 27, 2014 at 7:06 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Late model 11'a aren't included
  4. Oct 27, 2014 at 9:12 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    That would splain it.
  5. Oct 27, 2014 at 9:14 PM
    diesel305
    diesel305 Active Member
    miami, fl
    2011 tacoma prerunner DCSB trd sport
    Im one of late 2011 owners thats not on the recall list
  6. Oct 28, 2014 at 3:32 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    I would just tell them to give you the new leaf packs and install it yourself
  7. Oct 28, 2014 at 4:07 AM
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    I talked to my local dealer and the rep told me that if the add a leaf involves taking the leaf pack apart they may not be able to do it for legal reasons but would give the parts back without question. But if there is no legal reason he said they would do it for me. He said Toyota will tell them what they can and can not do with the recall.
    He also told me that he has no Idea what is going to happen wether it is a clip or new leafs.
  8. Oct 28, 2014 at 4:59 AM
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    that websight wont work for me.... I put in the vin and security code and it does nothing....
  9. Oct 28, 2014 at 5:55 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
  10. Oct 28, 2014 at 7:48 AM
    alpinebob
    alpinebob Well-Known Member
    bob
    alpine ca
    2008 Tacoma 4x4
    Caduceus, no, I did not. I bought it with 88K mi and did not know about the issue,
    I am guessing that unless the recall replaces the pacs, I will have to pay for a fix, either adding a leaf or air bags or???
    thanks
  11. Oct 28, 2014 at 12:59 PM
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    I'm not sure. I think that particular recall is just replacing the 3-leaf with a 4-leaf suspension. I think I had an AAL on at the time and the dealer left it (don't expect the same), and the back end was definitely a bit higher afterwards. I'd say the worst that happens is you call your dealer's service shop, tell them your problems, mention specifically that recall, and see what they say.
    I want to say it'll be free, but they probably have to order the part and kill a few hours doing it.
    I wouldn't even consider doing anything else to the rear suspension until you get the TSB issue figured out, as it might make things back to normal.
  12. Oct 28, 2014 at 9:07 PM
    EGoldie
    EGoldie Some Miles Under My Belt
    Evan
    Austin, TX
    08 DCSB TRD Sport 4x4
    OME 885/Dakars, 285/70/17 Toyo AT2, LR UCAs
    The rear leaf TSB was only good if your truck was still under warranty, correct? 36,000 miles?
  13. Oct 28, 2014 at 9:08 PM
    OZ-T
    Peter North
    British Columbia
    Yes
  14. Oct 29, 2014 at 12:18 AM
    cmyersgo
    cmyersgo Well-Known Member
    Carter
    Queen Creek AZ
    Well that sucks. I just found this tsb and I just bought my 07 tacoma with 150k and was wondering if people were having this problem with a load in the back. Pretty sure the previous owner didn't take care of the tsb... might try to talk to the guy I bought the truck from and see if they can't maybe work something out.
  15. Oct 29, 2014 at 5:19 AM
    #35
    alpinebob
    bob
    alpine ca
    2008 Tacoma 4x4
    Poop! This mileage limitation on the TSB is B S . If the springs or the construction is faulty, the company should simply replace the bad stuff. Mileage should have no bearing on the issue.
    As I said earlier my Gen 1 Taco was a great truck but I needed a larger cab (4Dr) and bought a 08 for that reason. So far I have front drive line rumble, center rear drive shaft bearing crapped out and now lousy springs??? Topped with LAWYERESE TSB/Recall policy!
    Oh well, all good things must come to an end!
    alpinebob
  16. Oct 29, 2014 at 5:31 AM
    #36
    h22dx
    h22dx [OP] Well-Known Member
    louisville,ky
    07 trd sport
    This is a recall not a TSB. A recall doesn't matter the mileage or warranty. As long as your truck is in the year range of what's being recalled. This is what I got from Toyota.
  17. Oct 29, 2014 at 5:43 AM
    #37
    EGoldie
    Evan
    Austin, TX
    The upcoming leaf spring issues is a recall and mileage won't be an issue. The previous leaf spring TSB was mileage dependent.
  18. Oct 29, 2014 at 6:07 AM
    #38
    h22dx
    louisville,ky
    07 trd sport
    Correct
  19. Oct 29, 2014 at 7:17 AM
    #39
    cmyersgo
    Carter
    Queen Creek AZ
    Oh I didn't realize there was 2 different ones. So how do I go about the recall then? Do they replace the leafs on this one as well?
  20. Oct 29, 2014 at 7:25 AM
    #40
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    Seriously, the easiest way to answer you is what I said earlier, go to the toyota owners site and plug in your vin and read the info it gives you.
    Summary: spring TSB only good for 36,000 miles or 36 months, whichevers first
    Spring RECALL: need to plug VIN in to see if you qualify and it's still in it's early stages and no remedy has been decided yet so there's nothing to do yet.
    I read somewhere that the remedy would be anounced nov 29, anybody verify that? I can't find the source anymore so I don't know if that's true or not.
