leaf spring bolt torque value ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by VBdiver58, Aug 28, 2018.
  1. Aug 28, 2018 at 2:08 PM
    VBdiver58
    VBdiver58 [OP] Well-Known Member
    Virginia
    1999 Tacoma xtra cab 4x4 2.7L
    16" Toyota rims
    replacing leaf springs on my 1999 ext cab 4x4 .
    anyone happen to know torque values (ft lbs) for bolts through bushings to frame and U bolts ?
    thanks very much
    my useless Hayes repair manual lacks that info
  2. Aug 28, 2018 at 2:14 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I believe its, im sure somekne will know for sure
    116 front eye
    60 shackles
    90 u bolts
  3. Aug 28, 2018 at 2:24 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Right column is ft-Lb
  4. Aug 28, 2018 at 2:26 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I was close lol
    ThunderOne[QUOTED] likes this.
  5. Aug 28, 2018 at 2:27 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Remember to check the torque on them a couple times every few hundred miles after initial install, the u-bolts especially lose a few ft. lbs of torque after you drive on them some.
  6. Aug 28, 2018 at 4:16 PM
    VBdiver58
    Virginia
    16" Toyota rims
    Thank You everyone .
    love this site and my Tacoma
    Sperrunner likes this.
  7. Aug 30, 2018 at 2:24 PM
    VBdiver58
    Virginia
    16" Toyota rims
    I wonder why the "leaf spring hanger pin bolt x frame "requires so much more torque ?
    that's a bear to do with a box wrench in one hand and torque wrench in the other . i improvised with a strap on the box wrench . no way to get a torque wrench on the nut with gas tank next to it .
  8. Aug 30, 2018 at 2:27 PM
    eon_blue
    Azusa, CA
    It's next to impossible to do on the side with the gas tank...the tank is in the way of getting a torque wrench on there. I ended up using the torque wrench on the bolt side and a box wrench on the nut, turned it until the box wrench wedged itself against the frame of the truck to keep it from moving and was then able to use both hands on the torque wrench.
    Ended up needing a pry bar to get the box wrench off though, lol. It got wedged in there pretty good from that.
    I think it requires so much torque because unlike the shackles, that eye isn't moving. The shackles need less torque so they can move back/forth.
