Leaf spring bolts
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoRich87, Aug 25, 2017.
  1. Sep 4, 2017 at 11:26 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Did you use that Acura as a jack stand? Lol
    unstpible and tacoRich87[OP] like this.
  2. Sep 4, 2017 at 11:32 PM
    tacoRich87
    tacoRich87 [OP] Active Member
    Lmao right!? My buddy in Acura just pulled up and parked like that haha
    jbrandt[QUOTED] likes this.
  3. Sep 5, 2017 at 10:36 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Hey theres an Acura under your truck.
    tacoRich87[OP] likes this.
  4. Nov 21, 2020 at 7:07 AM
    Brahms
    Brahms Well-Known Member
    Houston, TX
    2004 Tacoma DCSB 4x4 SR5 V6 TRD
    Do these bolts fit 01-04 Tacomas? I checked compatibility at few dealer sites and it recommended a $16 bolt (47936-35040), but the picture doesn’t look like what I need.
  5. Nov 22, 2020 at 8:30 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Yikes, old revival! :) :thumbsup:
    Those part numbers should work just fine for an 01-04, there's no change in that part between 95.5-04.
    Brahms[QUOTED] likes this.
  6. Jun 13, 2022 at 4:24 PM
    ottorocket757
    ottorocket757 New Member
    Zach
    2015 Toyota V6 SR5spd
    BS 6112/5160 Ironman4x4 440lb Leafpack
    I spent close to an hour attempting to remove the bolt from passenger side leaf front frame point. The bolt spun freely but the flange of the bolt would not separate from the frame enough to use a pry bar despite attempt with multiple chisels, the thread side couldn't be hit with a hammer due to the exhaust being in the way, and attempts to coerce it out with angry words were to no avail. I chose to cut it.
    I brought it the bolt from the shackle end to NAPA was told I needed a 14MMx1.5.110mm that they didn't have. Went to ace settled on a 14mmx1.5x100mm(10.9) with a nylon locking nut.
    Got back home went to install bolt threaded section went in fine but as soon as the smooth shaft met frame it stopped like don't hit me any harder or you'll bend the mount stop. After measuring shaft with caliper original bolt measured just under 12mm and new bolt measured just under 12mm as well. The threads on the original bolt did appear slightly larger than the shaft.
    I went back to ace purchased a 12mmx1.25.110mm(10.9). Currently that is what is holding the front of the leaf pack to the frame. Any insight as too what caused original bolt to stick or if I have made a grave error by replacing what I was told is (and was confirmed here previously as) a 14mm bolt that didn't fit with a 12mm bolt that did fit would be greatly appreciated.
  7. Jun 13, 2022 at 5:08 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    It might be your truck if your working on the 2015
    Your in the First Generation section.
  8. Jun 13, 2022 at 5:50 PM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    Can you send pictures of how your doing this.
