Leaf spring bolts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jayaye910, Feb 28, 2025.
  1. Feb 28, 2025 at 2:02 PM
    Jayaye910
    Jayaye910 [OP] Active Member
    I recently installed 3.5 different much leaf springs. I completely forgot to lube the bolts when putting them in. How can I go about taking one bolt out at a time and lubing them? Should I jack up the frame and take one out? I just don’t want anything to shift on me
  2. Mar 1, 2025 at 1:34 PM
    Flex-AZ
    Flex-AZ Well-Known Member
    Flagstaff, AZ
    2015 TRD Sport DCLB
    Camburg/Deaver mid travel
    You’ll want to jack up the rear and support the frame with jack stands. Then use either a jack, or better yet a jack and a second set of jack stands under the rear axle housing.
    winkel likes this.
  3. Mar 1, 2025 at 1:43 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Yes, I would do this and just take out one bolt at a time. I'd just use some Red N Tacky or wheel bearing grease.
  4. Mar 1, 2025 at 1:44 PM
    Jayaye910
    I appreciate you. I’ll give that a try thank you!
  5. Mar 1, 2025 at 1:45 PM
    Jayaye910
    yeah one bolt at a time. Red and tacky is all I have thanks
