Leaf Spring Bushings Annoying Squeak, ideas?
Discussion in 'Suspension' started by DeedleBag, Apr 7, 2011.
  1. Apr 7, 2011 at 4:45 PM
    DeedleBag
    DeedleBag [OP] Well-Known Member
    Houston, TX
    08 Tacoma TRD Prerunner
    Bilstein 5100, K&N Air Filter, Grillcraft
    Hey all, I am having this squeaking sound coming from my leaf spring rubber bushings. Yes I am completely certain this is where the sound is coming from. Anyone else have this problem and anyone know how to fix it?
  2. Apr 12, 2011 at 9:57 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Pressure wash your springs, spray heavily with lube (WD40 or something).
    Squeeky springs are from metal on metal (replace bushings) or dirt to metal (wash/lube)
  3. Apr 12, 2011 at 9:58 PM
    sierrahsky
    sierrahsky Expedition Style
    Josh
    Reno
    09 TRD Tacoma V6 Ex Cab | Extreme Sierra
    X2
  4. Apr 13, 2011 at 8:39 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If you decide to replace the bushings....make sure you get greasable ones. Search google for "Toyota tacoma greasable bushings"
  5. Apr 13, 2011 at 2:54 PM
    TRTaco
    TRTaco Member
    Craig
    Ontario
    '10 4cyl 4x4
    Rhino lined mirrors and rockers, All-pro front bumper, Fox 2.0 coil-overs, BFG KM2's, Illuminated 4x4 switch, Diff breather
    I had the same problem. There is a TSB on replacing the silencer pads between the springs. After i replaced them i had no more issues.
  6. Apr 13, 2011 at 3:12 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Couldn't find any for 2005 +
    Link ?
  7. May 1, 2012 at 8:15 PM
    rdm197aps
    rdm197aps Well-Known Member
    Rick
    DFW
    10 TRD Sport 4x4
    ARB bulbar WARN M8000, OME/Dakar, enough recovery gear to yank a GEO Tracker outta ditch!
    i know this is an old post, but i got the same thing going on since ive been going off road... running out side to grease mine up... white lithium should do...
  8. Sep 11, 2015 at 4:47 PM
    Todb
    Todb Member
    2008 Tacoma TRD
    Spray with PB Blaster, then pressure wash, then lithium spray.
