Leaf Spring Bushings?
Discussion in '1st Gen. Tacomas (1995-2004)' started by pincheguero, Jan 27, 2014.
  1. Jan 27, 2014 at 12:22 PM
    pincheguero
    pincheguero [OP] Member
    CA
    03 Prerunner SR5
    My 03 Prerunner has a nasty squeak when going over bumps. I am replacing shocks currently, but have been told this may be a leaf spring bushing issue.
    I've been told that these are extremely hard to replace on a 10+ year old truck - any advice here?
    Thanks!
  2. Jan 27, 2014 at 12:30 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Start soaking them in penetrating oil or WD-40. If the bushings are worn out it will help them come out easier. If they're in good shape but noisy, it will help that, too.
  3. Jan 27, 2014 at 12:37 PM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    well I'm pretty sure the leaf springs are just like the control arm bushings. there is a metal bushing that is pressed in there that needs to be removed.. once its removed replacing the bushing is as simple as lubing the bushing then tightening a nut and a bolt pretty much. there are a few DIY methods i have seen but have not attempted. check out youtube. you don't have to look for a tacoma specific video all leafs are the same pretty much.
  4. Jan 29, 2014 at 8:41 PM
    Zer0
    Zer0 Well-Known Member
    SGV, California
    99 PreRunner
    just get new leafs. you can pick up some nice Dorman leafs for a little over 100 bucks brand new!
    Look at the bolt that goes through the bushing. if the bolt doesnt look like its in the middle of the bushing then your bushing is probably bad.
