Leaf Spring Bushings
Discussion in '1st Gen. Tacomas (1995-2004)' started by old grouch, May 3, 2023.
  1. May 3, 2023 at 4:02 PM
    old grouch
    old grouch [OP] Well-Known Member
    Stan
    Colorado Springs, CO
    95 4x4 V6 Extra Cab
    E-Locker SS Skid 2" Lift
    Has anyone replaced the bushings in the rear shackle without removing the springs? If so, how did you go about it?
  2. May 3, 2023 at 4:26 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I only messed with them changing springs.
    Installed all new parts after torching the old ones off.
    I have never removed them without cutting them off.
  3. May 3, 2023 at 4:35 PM
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
    I replaced all the bushings on mine with energy suspension. Used a harbor freight ball joint press, liberal ATF, long handle break bar and determination. Jack stands, floor jack and worked each end without fully removing the springs. There are some Youtube vids out there to give some guidance. Changed the leaf springs out previously and can say if you need to remove them it's not as bad a chore as you would imagine. SC truck so no torch needed.
  4. May 3, 2023 at 6:39 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    You have to take enough weight off the rear of the vehicle so the springs have no load and aren’t arched with the weight of the axle/wheels. If you can find where the springs are at their natural arch the distance between the upper and lower eyes of the shackle shouldn’t have any bind other than the resistance of the bushing on the shackle itself. An inch or so in either direction is probably okay if you can muscle it out, might have to get crafty, ie c-clamps or puller that fits. I’ve done it, definitely possible
  5. May 3, 2023 at 6:56 PM
    TragicBronson
    TragicBronson Well-Known Member
    Eddie
    Pflugerville TX
    2003 Tacoma Dbl cab SR5 4WD
    This. Jack up the truck safely on jack stands + blocks, use the (now free to use) pump jack/floor jack to relieve spring tension(bind) on the rear differential and find the "sweet spot", then remove and replace shackle.
    I can definetely see some wrenches being thrown in order to line up the shackle bolts into place for the new part if the "sweet spot" isn't found. Been there, did that.
