leaf spring center bolt torque
Discussion in 'Suspension' started by 09sr5, Dec 22, 2012.
  1. Dec 22, 2012 at 8:21 AM
    09sr5
    09sr5 [OP] gonna be a long ride
    East Tennessee
    2009 sr5 2.7 4x4 AC
    265/75 AT3's on stock wheels. 5100's@1.75". Trail Gear sliders. Toytec AAL
    Does anyone know it off hand? Fixing to start on my aal. Its an 09 model. Thanks!
  2. Dec 22, 2012 at 8:38 AM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    No torque spec just tight. Look at chris4x4's write up and there are specs there except for that bolt.
  3. Dec 22, 2012 at 8:42 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Usually that is about a 3/8" diameter bolt, but hardened and threaded all the way through. I would say about 50-60ft/lb. NO antiseize since removal will probably require grinding or torching.
    Or in laymans terms, two grunts and a fart. You want it tight enough to compress all the leaves together firmly, with just a little stretch. The nut will strip long before the bolt does.
    A couple of C-Clamps often helps it get started and remember, cut off the excess with a hacksaw or abrasive wheel, careful not to take the temper out of it.
    I have been building spring packs for decades.
    Howard
  4. Dec 22, 2012 at 8:44 AM
    09sr5
    East Tennessee
    2009 sr5 2.7 4x4 AC
    Alright thanks guys
  5. Dec 22, 2012 at 8:50 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Around 50-55 ft lbs IIRC
  6. Dec 22, 2012 at 8:58 AM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with MCM front kit
    German spec: Gooodntight
  7. Dec 22, 2012 at 9:00 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    This too...;)
  8. Dec 22, 2012 at 12:32 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    The stock bolt is only around 55 ft/lbs...
    but I have had those come loose over time
    during severe duty when flexing things out off road.
    If the center bolt comes loose... the individual leaves could possibly fan out.
    Sooo... I replaced mine with a grade 8 cap bolt/nut
    and torqued that down to around 75 ft/lbs.
    It's been several years now...
    and nothing has worked loose, malformed or broke
    * I recommend red locktite when installing.
  9. Dec 22, 2012 at 12:40 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Yep , had that happen before I try to use either a rated nylock or I'll tighten down & back it up w/nut (dbl nut)
