Leaf Spring center pin (Lowes), lift pics, info (FINALLY DONE)!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, Oct 19, 2012.
  1. Oct 19, 2012 at 6:36 PM
    TAC1
    TAC1 [OP] Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello Forum,
    I had a damaged center pin on my right leaf spring yesterday on my '08 DCSB Prerunner 4.0 & I wanted to be done with my truck by tomorrow since I will be on vacation next week. I could not find the pins locally so I posted a thread yesterday & got some good responses. I liked Hans Moleman's suggestion best but I wanted to find those bolts locally since I was pressed for time.
    I found these at Lowes & I will provide the part #'s in case someone is in a similiar situation that I was in & can't wait for delivery.
    Bolt part #880335 $1.87 (each).
    Nut part #880269 $1.21 (pack of 4).
    I trimmed the heads height down to match the height of the OE center pin but I think it would hae fit regardless, not sure though.
    Now, I finally have the vehicle at the level that I wanted. I have:
    Billies on all 4 corners (front @ .85).
    2012 TRD 2/1 leafs with Wheelers 3 Leaf AAL (I left the OE overload leaf but removed the smallest leaf from the 3 leaf AAL) & Hellwig EZ550 to firm the rear a little. I was actually thinking of adding the OE overload leaf from my original leafs to this leaf pack also to gain another .5" of lift but I did not want to push it into "BAD VIBE" territory. Here are some pics, ENJOY!
    Original Height specs (from ground to fender base with P265/70r16 General HT's):
    LF 34.00 / RF 34.50 / LR 35.25 / RR 35.50
    Current height specs (from ground to fender base with LT265/75r16 BFG A/T's):
    LF 36.25 / RF 36.00 / LR 38.00 / RR 37.75
    Chassis height measurements (current specs, never measured before today):
    LF 15.25 / RF 15.00 / LR 16.25 / RR 16.00
    When it is on level ground it looks slighly higher in the rear. I'm glad because I don't want it level or nose high. I understand most people here like them leveled & some even nose high but I am just old school that way.
    BTW: I measured the chassis on all four corners right before they bend up in the front & back.
    THANKS:D
  2. Oct 19, 2012 at 6:40 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  3. Oct 19, 2012 at 8:30 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Thank you!
    Nice rims BTW. What size and brand are they?
  4. Nov 26, 2013 at 10:24 PM
    rjjencke
    rjjencke Well-Known Member
    Robbie
    Arizona
    '15 MGM DCSB OR 4x4 JBL
    +1 you are a genius!! No 4x4 or auto store in AZ had a centering pin with a big enough head for a Toyota!!
    I used your part number and it worked perfectly after I stripped out both of the pins that came with my Toytec kit!
    However, I got the 2.5" instead of 3" and it was perfect. (I already had the leafs clamped).
    Old thread but thanks!!
  5. Nov 27, 2013 at 4:58 AM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Thank you but I can't take all the credit. I read this info somewhere. I think it was in this forum but they didn't post the part #. I'm glad it helped you out :D
    BTW,
    Which Toytec lift kit did you go with?
    Thanks
  6. Nov 28, 2013 at 12:47 PM
    rjjencke
    Robbie
    Arizona
    The 3" best seller. 884 springs with top spacer and a 1.5" AAL.
    Loving it so far!!
  7. Nov 29, 2013 at 3:42 AM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Awesome!
  8. Nov 29, 2013 at 4:22 AM
    J0HN_R1
    J0HN_R1 Well-Known Member
    Calgary, Alberta
    2014 Tacoma TRD Sport DCSB
    Bilstein 5100's @ 2.75" FR, Deaver 1.5" TSB leafs RR, SpiderTrax 1" spacers, custom LED interior & bed lights, 2005 4Runner Sport 17" wheels powder coated satin black
    I would try to eliminate the "rake" (& loose the Chevy wheels, & pinstripe) if I were you. But I'm not...
    As long as you're happy with it. ;) Looks good though !
  9. Nov 30, 2013 at 6:13 AM
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    great post!!
  10. Jun 5, 2015 at 8:06 PM
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Just for clarification, the part numbers above are the Hillman brand numbers, not the lowes numbers. The lowes numbers are:
    Bolt: 80411
    Nuts: 136068
    However I recommend getting nylock nuts, part number: 215535
