Leaf spring center pins????
Discussion in 'Suspension' started by ETaco23, Jan 23, 2011.
  1. Jan 23, 2011 at 3:09 AM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I have a quick question for all you... When I did my AAL install I stripped out one of the center pins, and had to go find another one at a hardware store.
    Well I had no luck ofcourse, But instead I used a allen head pin. Was wondering if this is ok, or should I just order a new set of center pins?
    If you dont know what Im talking about......
  2. Jan 23, 2011 at 8:09 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You used an Allen Head Bolt?
    As long as it's tightened properly and the 'head' of the bolt seats into the hole on the spring perch by atleast 1/8" (and that's a guess)...... AND .... your u-bolts are torqued properly and stay torqued....AND you have the proper leaf spring clamps on (to prevent fanning)...
    You should be OK.
    Making sure your u-bolts are kept tight is the KEY.
  3. Jan 23, 2011 at 8:10 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
  4. Jan 23, 2011 at 8:35 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x3^^^^^^^^^ 38k ago
    all is well
  5. Jan 23, 2011 at 12:30 PM
    ETaco23
    Evan
    PNW
    Awsome! so I shouldnt have any issues.
    I just retorqued my suspension yesterday and my u-bolts were pretty loose. :(
    good thing I caught it.
  6. Jan 23, 2011 at 12:35 PM
    Sapper26
    Sapper26 Well-Known Member
    Will
    Columbus, GA
    99 Xtra Cab 4x4
    I just grinded down a hex head until it fit in the hole. Been running it now for 6k miles and no issues.
  7. Jan 23, 2011 at 12:39 PM
    ETaco23
    Evan
    PNW
    ^^ I did that with my 02 tacoma. :)
    worked like a charm.
