Leaf spring cracks, how unsafe?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by indiangk87, Jan 2, 2022.
  1. Jan 2, 2022 at 3:09 PM
    Montana_Actual
    Montana_Actual ;)
    wi_taco likes this.
  2. Jan 2, 2022 at 3:15 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    check out the Icon RXT leaf pack
  3. Jan 2, 2022 at 3:53 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    Not only is that leaf spring broken, it's been broken for a while, giving the amount of rust present where the break is located. Look at the way the spring is curled up right at the breaking point. Someone overloaded the hell out of those springs and broke one. Don't drive that truck anymore.
    wi_taco likes this.
  4. Jan 2, 2022 at 3:55 PM
    indiangk87
    indiangk87 [OP] Member
    Tom
    2015 Tacoma OR DCSB
    thanks for all the input guys. very helpful that the clear consensus is to stop, drop, and replace those leaf springs..yesterday.
    okay so now i need to get together a replacement strategy ASAP.. any recommendations of DC area shops? have heard lots of recs for @DOUBLLD in Sterling, VA but uncertain if he’s still doing work. any other body shops in the area that anyone has used would be recommended.
    thoughts on a recommended setup? want minimal lift. will be loaded for trips (~300lbs) but daily only some tools and a hard tonneau in the back (~100lbs)
    leaf springs packs:
    OME packs? (is dakar for having a constant load in the bed? cuz i prob only have ~100lbs in there on avg, max 300lbs, no towing)
    Does anyone have experience with these GeneralSprings? these look like pretty close to oem replacements that dont cost $750(thats what the toyota dealership said it would cost for the oem leaf spring assembly)
    https://www.generalspringkc.com/200...ner-heavy-duty-rear-leaf-spring-4-3-1-leaves/
    sounds like if I replace springs in rear i should at least replace front struts. am thinking of 5100s all around (or maybe juat front)…overkill?
    DOUBLLD likes this.
  5. Jan 2, 2022 at 3:56 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Dakar’s are noisy and eventually sag, my next set will be Deavers.
    Hobbs likes this.
  6. Jan 2, 2022 at 4:00 PM
    Clearwater Bill
    Billy
    Largo Florida
    For your defined use, you might look for a fresh set of 3rd gen take offs.
  7. Jan 2, 2022 at 4:05 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    If the shocks are original on a 6 year old truck replace all of them , front and rear. Since the truck is not lifted replace them with Bilstein 4600 heavy duty. They are made to replace the originals but are far better shocks than the originals. They are the same as 5100’s but for non lifted trucks and a little less $$.
    whatstcp likes this.
  8. Jan 2, 2022 at 4:15 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Don't bother with the dealer, somewhere in your area there has to be a truck spring shop. It won't be a chain (Monroe, etc.) and they won't do mufflers and brakes -- just springs. Call a local towing company and ask who does their spring work.
    This is their bread and butter, they can probably have you back on the road and safe in a few hours for a fair price.
    deanosaurus, blu92in99 and VE7OSR like this.
  9. Jan 2, 2022 at 4:17 PM
    indiangk87
    Tom
    2015 Tacoma OR DCSB
    how do these compare to OME EL111R? they seem more expensive. are these heavy duty vs medium duty?
  10. Jan 2, 2022 at 4:33 PM
    indiangk87
    Tom
    2015 Tacoma OR DCSB
    whoa. thats a quality tip! am gonna give the local guys a call tomorrow, apparently they are ~10min away. really hope they have enough on hand
  11. Jan 2, 2022 at 4:38 PM
    indiangk87
    Tom
    2015 Tacoma OR DCSB
    if i end up getting replacement leaf springs that lift the rear by a couple inches (idk that ive been able to find leaf springs without some lift), should i then get 5100s or you think the 4600s will still be good to go? also whats this i hear about a taco lean..?
    im as new as it gets to owning a taco, if you cant tell. so thank you so much for answering lots of annoying questions.
  12. Jan 2, 2022 at 5:07 PM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    A spring shop will have a catalog showing the original spring rate and any optional spring rates available. This is what these guys do every day, they should be able to fix you right up.
    VE7OSR and davidstacoma like this.
  13. Jan 2, 2022 at 5:14 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
  14. Jan 2, 2022 at 5:51 PM
    Sonofliberty92
    Sonofliberty92 T O Y O T A
    Mark
    Maryland 4 South
    2014 DCSB TRD OR, 2005 Tundra V8 4WD
    Taco lean is where the truck leans left a slight because of the gas tank and the driver. It's the way they all are.
  15. Jan 2, 2022 at 6:26 PM
    #35
    indiangk87
    Tom
    2015 Tacoma OR DCSB
    thanks for all the help with this problem. hopefully ill get sorted out by the spring shop tomorrow and then ill slowly try to work on a suspension overhaul. im thinking if they busted up this leaf that some new struts will be a good idea sooner than later
  16. Jan 2, 2022 at 6:45 PM
    #36
    Clearwater Bill
    Billy
    Largo Florida
    Shocks.
    Tacomas dont have struts. Regardless of the words vendors and the internet may use.
  17. Jan 2, 2022 at 6:58 PM
    #37
    Sharpish
    Brian
    The front suspension is struts/coils and the rear shocks/leafs.
  18. Jan 2, 2022 at 7:00 PM
    #38
    Sprig
    Ken
    Ask the shop that does the leafs. Don’t know until you know for sure what leaf’s you’re you are going to get.
  19. Jan 2, 2022 at 7:15 PM
    #39
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Incorrect
    A strut suspension is when there is no upper control arm and the shock body bolts directly to the top of the knuckle. There will be an upper strut mount that has to rotate on a bearing while steering. There will only be one control arm - at the bottom. Subaru is a good example
    Tacoma is a SLA (short/long arm) suspension. The knuckle is held in place by 2 arms, the shock is not involved in steering left/right
  20. Jan 2, 2022 at 7:19 PM
    #40
    Clearwater Bill
    Billy
    Largo Florida
    The front is IFS double wishbone coil-over-shock.
    Taco 422 likes this.
