Leaf Spring Eye Bolt Stuck!
Discussion in 'Suspension' started by ghs57, Sep 11, 2010.
  1. Sep 11, 2010 at 3:58 PM
    ghs57
    ghs57 [OP] Well-Known Member
    Chops
    Catskill Mts. NY
    '03 Black SR5 xtracab 2.7L 4WD
    Pretty much stock with a small lift and Timbrens
    Anyone know a way to get these GD stuck eye bolts out? I think they have rusted to the bushings. There's no room to swing a hammer on the drivers side (gas tank), but even on pass side I can't break it loose.
    I didn't expect to spend all day on this, but my black and tan '01 just dosen't want to give up the broken OEM springs.
  2. Sep 12, 2010 at 5:57 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are you talking about the getting the shackles out?
    Or are you talking about the front eye bolts? Or both?
    They are a royal pain in the ass, I've done countless lifts on 1st gens and the eye bolts are a bitch. YES, they are rusted up. There's a metal sleeve in there that the bolt slides in and they rust together.
    We used to spray the livin shit outta the bushings with PB blaster for days and that wouldn't even help.
    You're probably gonna have to cut the head of the bolt off as flush as you can and then pry the mounts outward so the entire assembly can slide thru it. You'll need new bolts and bushings....get greasable shackle bolts!!!
  3. Sep 13, 2010 at 5:59 AM
    ghs57
    Chops
    Catskill Mts. NY
    Both front bolts were stuck. I'd have bet real money someone had welded them in. I finally realized, as you suggested, that I needed to cut them loose. They're out now, but that was a battle. I hope to finish the job up after work today.
    I had the foresight to order the greasable bolts along with the new springs from Wheeler's.
    Thanks much for the advice.
  4. Sep 13, 2010 at 8:59 PM
    ghs57
    Chops
    Catskill Mts. NY
    Just a note to anyone replacing rear leaf springs. Buy new U bolts. You may be able to save the old ones, but I don't think it's worth the effort. The greaseable shakel and eye bolts will also save you or someone else a ton of work down the road.
