Leaf Spring help? add-a-leafs?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by vtac, Mar 24, 2022.
  1. Mar 24, 2022 at 8:50 PM
    vtac
    vtac [OP] Well-Known Member
    2017 Tacoma TRD OR DCSB
    Hi I have a 2017 tacoma OR. I had the suspension done years ago can't really recall how much lift I got out of it but it was Bilstein 5100s all around, OME 888s and Dakkar Leafs medium duty, SPC UCAs. I really didn't have any issues with this set up until recently where I added quite a bit of constant weight.
    Smart Cap + Alucab rtt + rear steel bumper is about 500 lbs constant weight.
    I'm experiencing some sag. the leafs are pretty much flattened out. I hated these leaf spring with the ridiculous squeaks and fixes that wouldn't last too long.
    I'm looking for an inexpensive fix. I have brand new factory leaf springs I kept around. Is there any add a leafs that would work well in my situtation? or should I keep the dakkars and add a leaf?
    I'm a noob with anything suspension. TIA
  2. Mar 24, 2022 at 11:25 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I’m not sure where I saw this but I read somewhere that you could use other leafs from stock as a donor and add them to your existing with the add a leaf.
  3. Mar 25, 2022 at 11:20 AM
    vtac
    Thanks, I'm going to have to look this up!
  4. Mar 25, 2022 at 11:23 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Flat leaf springs is not a problem. It’s completely normal. But if you still want to increase your spring rate, you can get a leaf from ARB that turns your medium Dakars into heavy Dakars.
  5. Mar 25, 2022 at 11:27 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Look into helpers like “Sumo Springs”.
  6. Apr 4, 2022 at 1:50 PM
    Wile_E_RedDog
    Wile_E_RedDog Well-Known Member
    Terry
    Sacramento, CA
    2008 Silver Tacoma OR Baja DCSB
    AT Overland Summit,
    I helped a buddy do exactly this. Easiest fix for the increased weight.
