Leaf Spring Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by letters85, Dec 2, 2019.
  1. Dec 2, 2019 at 9:36 AM
    letters85
    letters85 [OP] New Member
    2001 Tacoma single cab 4x4
    Hello, my name is DL. I recently purchased another Tacoma, Gen 1 this time. I broke a leaf the other day and it has fast forwarded my plans to do anything to this truck yet. I currently commute at least once a month from Harrisonburg, VA to Jacksonville, FL so I'm trying to retain the normal ride and mileage when I replace it. I'm having a heck of a time finding a definitive answer regarding the part numbers and apparently the leaf springs are not interchangeable. details on the truck: 2001 Tacoma Single cab 4x4 2.7L
    If anyone could point me in the right direction to finding suitable replacements either aftermarket or OEM I would greatly appreciate it. just not trying to spend an arm and a leg right now. (my wife is already mad enough about it) thanks again and I look forward to talking to yall.
    Regards, DLM
  2. Dec 2, 2019 at 9:46 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    General Springs is talked about when looking for an OEM variant.
    Welcome to the forum btw
    Wyoming09 likes this.
  3. Dec 2, 2019 at 9:50 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    What do you mean not interchangeable? Interchangeable with what?
    If you are not wanting to lift it, you have three basic choices. OEM ($$$), General Spring ($$), or any of the various semi generic "brands" from RockAuto.
    https://www.rockauto.com/en/catalog/toyota,2002,tacoma,3.4l+v6,1388987,suspension,leaf+spring,7544
    https://www.generalspringkc.com/Leaf_Springs_Toyota_Tacoma_2001_2002_2003_2004_s/1932.htm
    https://parts.camelbacktoyota.com/o...9MjAwMSZ0PXByZS1ydW5uZXImZT0zLTRsLXY2LWdhcw==
    (this is for ONE side)
  4. Dec 2, 2019 at 10:08 AM
    letters85
    went with general spring. they were the only one that identified them well enough for me to comfortably order them. ill let yall know what I find out about the installation. thank you for your replys.
  5. Dec 2, 2019 at 1:27 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    New u bolts and spring shackle kits plus the bolts for the spring hangers.
    Will make this job lots less frustrating having learned this the hard way
  6. Dec 2, 2019 at 5:05 PM
    Hamer95USA
    Hamer95USA Well-Known Member
    1999 Toyota Tacoma 4x4 SR5 extended cab reborn!
    Complete OME suspension kit, Used low mileage V6 engine swap, black powder coated Chou Seiki T15x7JJ, ARB deluxe bumper, Smitty Bilt nerf bars, Weathertech floor liners, Torklift tiedowns
    I had this issue years ago when I was carrying a bunch of music gear to a show with a friend as a passenger. I drove to the show and heard something break, but had no idea what it was at the time. I return from our trip, drop my friend off, and go home. I had to drive somewhere, heard something metallic moving around in the back of the truck, and pulled over. I saw a broken leaf from the leaf spring pack hanging out from the rear passenger side of the truck. I drive back home, duct tape the broken leaf spring back into the leaf spring pack, make a few phone calls to the local junkyards, locate a used passenger side leaf spring pack for $100, and take it to the local auto repair shop that my friend worked at. He installed it for around $100 and that was the end of it. Since I had my OME suspension kit installed, that leaf spring that I bought from the junkyard is sitting in the garage collecting dust now.
  7. Dec 6, 2019 at 7:05 AM
    Willstutz7
    Willstutz7 Self-proclaimed, unjustified expert
    Will
    2003 TRD Off-road Extra cab V6 Prerunner
    3” allpro leaf springs; Bilstein 5100 shocks all around; thrush welded muffler back system; deck plate mod; 1.5” wheel spacers; rear led bumper light pods
    When replacing leaf springs you should replace ubolts too. They stretch over time and stretch when being loosened and tightened again. Make sure they are torqued to spec and then checked again for stretching after about 500 miles
    2002Tacoma4x4 and Hamer95USA like this.
  8. Dec 6, 2019 at 9:06 AM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    I just glance this thread... OP pulled the trigger with general..... IMHO... i will check Michigan truck springs... they have OEM specs to keep stock high, spec for Right and Left , both for about 600 shipped..... I will keep this in mind for whenever i get that budget :spending::mudding:
    GQ7227 likes this.
  9. Jan 11, 2020 at 5:43 AM
    2002Tacoma4x4
    C K
  10. Jan 11, 2020 at 11:45 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    2002Tacoma4x4[QUOTED] likes this.
  11. Jan 11, 2020 at 1:38 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    When you start to groan and creek you no longer notice the truck
  12. Jan 11, 2020 at 4:40 PM
    underaroof
    underaroof ember
    Eastern Sierra
    2004 Xtracab 4x4 V6 TRD
    I went with General HD's, minor lift but I'm satisfied.
  13. Jan 12, 2020 at 3:30 AM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    How minor a lift and whats the ride like?
  14. Jan 12, 2020 at 6:27 AM
    2002Tacoma4x4
    C K
    are these cheap ?what would you recommend buddy?
    I would rather keep stocK and smooth drive on highway 99.99 % of time
  15. Jan 12, 2020 at 8:21 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Lemme rephrase what I said. Dont go with no name brand springs. A lot of people on here use General and have good results. I went with SD springs because they were cheaper but Ive never heard of anyone using them. Like I said earlier, I regret it. If you want oem spec springs, go General.
