Leaf Spring install nightmare
Discussion in '3rd Gen. Tacomas (2016-2023)' started by horribleharp, Sep 20, 2021.
  1. Sep 20, 2021 at 11:46 AM
    horribleharp
    horribleharp [OP] Member
    2019 Silver Tacoma Off Road
    Hey guys,
    Yesterday a few buddies and I attempted to swap out my leaf springs. Normally this is a rather simple feat, but for us it turned into a nightmare...
    I have Atlas expedition leaf springs that are 2 inches over stock height. We could not for the life of us get them to mount from the front spring mount to the rear shackle. We thought maybe drop shackles would help so I bought 2 inch drop shackles from the local Autozone only to find out that they smack my frame. It might be helpful to mention that I do not have stock hangers, I'm running Archive Garage hangers with stock shackles.
    Anyone on here have any advice on how to install my new leaf springs? Also, if I do get them on, would my rear be significantly higher than my front? (I have only icon UCA's and King 2.5 coilovers up front)
    Thank you in advance!
  2. Sep 20, 2021 at 11:49 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
  3. Sep 20, 2021 at 11:51 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    What do you mean “couldn’t get them to mount”? Holes didn’t line up or you physically couldn’t get them in place? Pics might help.
    kgilly, wilcam47 and tcjacado like this.
  4. Sep 20, 2021 at 11:51 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Are you sure Atlas sent you the correct leafsprings?
    Mark77, Bodyguard89 and pltommyo like this.
  5. Sep 20, 2021 at 12:02 PM
    horribleharp
    Yes, I phone ordered them. I mean they say they are correct for my year? Not sure how else to truly check if they are correct. I'm assuming due to the 2inch lift they do not easily mount from front mount to rear shackle.
  6. Sep 20, 2021 at 12:04 PM
    horribleharp
    Not entirely sure of the measurement but with the front spring mount bolted in, the rear mount if roughly half a foot from my rear shackle. Now I don't have a lift, so we were attempting this with jacks and jack stands and my brake lines were still connected. My lines were fairly stretched (with some play) so if I were to lower my axle even more, I would be concerned. Thusly making me wonder if I need drop shackles or something else entirely.
  7. Sep 20, 2021 at 12:14 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Are you running Archive garage hammer hangers or their old shackle flip kit?
    sawbladeduller likes this.
  8. Sep 20, 2021 at 12:36 PM
    horribleharp
    I have the Hammer Hangers with OEM shackles.
  9. Sep 20, 2021 at 12:37 PM
    horribleharp
    I unfortunately have no pics from our attempt. With the front part of the leaf spring bolted in the front mount, the rear mount of the leaf spring is roughly 4-6 inches in front of my rear shackle and hanger. My buddies and I thought we could bend it back to mount it but it's just too much to bend.
  10. Sep 20, 2021 at 12:38 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    6 inches short = a lost girlfriend
    6 inches short = wrong springs
  11. Sep 20, 2021 at 12:40 PM
    horribleharp
    You think so? How would I even go about that with Atlas? Their customer service wasn't the best to begin with.
  12. Sep 20, 2021 at 12:41 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I was able to do my Deaver stage 2s by myself :notsure:
  13. Sep 20, 2021 at 12:41 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    You likely needed to drop the axle even more, unbolt the brake lines
  14. Sep 20, 2021 at 12:47 PM
    OdiN1701
    OdiN1701 Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    Uhm...not sure what this has to do with anything. The springs aren't even attached to the axle at this point. Okay...well they SHOULDN'T be. You would mount them to both spring hangers first, then attach the axle back.
    I agree - 6 inches short is the wrong spring.
  15. Sep 20, 2021 at 12:53 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Drop the axle further. Shackle on the leaf first and in the hanger first. Slide the front in. Use a ratchet strap around the axle to pull it forward if needed. There's a nice hole in the frame to attach to, or use your sliders if you got them.
  16. Sep 20, 2021 at 12:58 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    The brake lines are attached to the rear axle by way of a mounting bracket. Remove the 12mm head bolt from the axle, pull up on the brake lines slightly. This will give the rear lines more room to stretch.
    Here:
    71tattooguy and tcjacado like this.
  17. Sep 20, 2021 at 1:01 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    everytime i've swapped springs I get the front mounted first and then the rear in to the shackles before bolting on to the axles. So you need to droop your axle enough so that the spring isn't touching it.
    But it sure sounds like your springs are too short... or possibly have so much arch in them that the mounts don't line up, which still isn't right.
    Mark77 likes this.
  18. Sep 20, 2021 at 1:06 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    It sounds like you have the wrong springs. It should be obvious by comparing them side-by-side the stock springs you took off. They should have the same eye-to-eye distance. Someone correct me if I am wrong. I've installed leafs just once before and it was 1.5 years ago. It was a PITA getting everything to line up, but nothing like 6" off.
    CherylJane and brandon78lusch like this.
  19. Sep 20, 2021 at 1:08 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Do you have pictures of original vs new. They should be essentially the same length. My new spring on top, original on bottom.
    Mark77 and 71tattooguy like this.
  20. Sep 20, 2021 at 1:08 PM
    OdiN1701
    Colorado
    If the axle was pushing on the leaf spring, wouldn't that extend the ends because you're compressing the spring? Not make it too short?
    I guess that would be a SOA setup though...not SUA.
