leaf spring install...OEM's seized
Discussion in '1st Gen. Tacomas (1995-2004)' started by NegroTundra, May 17, 2011.
  1. May 17, 2011 at 10:48 PM
    NegroTundra
    NegroTundra [OP] Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    So my new Dakars are sittin in the corner of the garage for the second straight day and here I am still struggling with the original leaf spring bolts. I have done everything humanly possible to free the front main eye bolt on the drivers side, but it is so seized with the bushing sleeve that I am going to have to cut. I've got my angle grinder out but before getting after it I realized I am inevitably going to be slop cutting into the hanger. I only want to cut the bolt-head-side so that it slides out when I'm done, but of course it is seized such that the leaf is pushed up against that side, giving no room to cut. Yes I tried PBlaster and a sledge to try and nudge the leaf over for suffucient cutting space but no love. I am wondering what you guys used to cut your front main eye bolt. Thanks for any help. Oh yeah one last thing...does Toyota dealerships supply these bolts? If not I suppose Home Depot grade 8 equivelants will do fine...
  2. May 17, 2011 at 10:54 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    sawzall would do it, you might go through a few blades though.
  3. May 17, 2011 at 11:43 PM
    Norton
    Norton Senior Member
    Monument, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I feel your pain, having gone through the very same thing with BOTH my eye bolts. I ended up biting the bullet, and having a garage remove them. Doing so involved multiple cutting/grinding wheels, an air chisel, a cutting torch. and several hours of labor. :eek:
  4. May 18, 2011 at 3:19 AM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    For the main spring eye bolts you'll definitly need either a grinder or sawzall. The passenger side one you can just cut off the bolt head and pop it out the other side but for the driverside one you'll need to cut off both bolt and nut since the gastanks prevents u from pushing it directly out. A holesaw works good for gettin the seized bushing out from the spring eye as well, I assume you've got new ones to go in after eh.
  5. May 18, 2011 at 4:53 AM
    Enigmaaron
    Enigmaaron All your soul are belong to us
    PA
    1st gen superiority
    Had the same thing happen to me when I put Dakars on. Didn't have a sawzall at the time. My dremel tool with about 5 cutoff wheels cut through it and I didn't mess up the hanger.
  6. May 18, 2011 at 5:07 AM
    4x4Runner
    4x4Runner Now with more Oi Vey! Moderator
    Drunken Sailor
    Somewhere between Maine and Florida
    2017 4Runner Smashed Ass Edition
    KDSS
    Ran into the same issue when I installed my Dakar's. I used a sawsall to cut it. Fortunately I know someone who had a bucket-o-bolts and has the correct bolts for the springs.
  7. May 18, 2011 at 5:17 AM
    Enigmaaron
    PA
    1st gen superiority
    It's been a while but I thought the bolt was a standard one I was able to get at a local hardware store. Just so the OP knows he doesn't have to worry about hunting down a specific bolt. Although I wish mine was greasable, I'm pretty sure the main point of squeaking in my leafs is coming from this bolt.
  8. May 18, 2011 at 6:01 AM
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    ^ THIS!
    Same thing happened to me! It took me a good 2.5 hrs of sawing, hammering, and cussing to get it off, but eventually it came out.
    You can also order those bolts from Wheelers Offroad. If you go to Home depot, or similar I would definitely make sure its a grade 8 Bolt.
  9. May 18, 2011 at 6:08 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Have you tried giving it a little heat to remove the bolt? Obviously you'd have to be very careful since it's on the truck and I wouldn't recommend trying it if you've never used a torch before.
    Otherwise, sawzall or a dremel with a cut-off wheel are probably your best bet as mentioned above to cut it off. If the botl is seized up solid, have you thought about using a long extension or pipe on a breaker bar and snapping the head of the bolt off?
  10. May 18, 2011 at 6:10 AM
    NegroTundra
    Land of Enchantment
    Thanks for replys guys....rollin up the sleeves once again...
  11. May 18, 2011 at 6:45 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Same thing happened to me with both front eye bolts. Took a few hours and multiple blades on a sawzall as well as an angle grinder. Major pita, good luck.
  12. May 18, 2011 at 11:10 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    I used another bolt and a bfh to hammer it through in coordination with a grinder
  13. May 18, 2011 at 12:54 PM
    NegroTundra
    Land of Enchantment
    Finally got it....took about 2 hours and multiple trips to home depot for more and more blades for the sawzsall. Finally tracked down some thin grinder discs for my angle grinder and those went through the bolt like butter. Wish I woulda started it with those..
    Anyway, time to get Dakars on!
  14. May 18, 2011 at 12:55 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Nice. I thought you already had the thin cutting wheel and it wasn't working:eek:
  15. May 18, 2011 at 1:46 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Nevermind you got it, Nice !!
    Yeah sawzall would, I don't think he'd use too many blades, steel is fairly soft, OP did you use a torch to heat shit nice & toasty ? (heat around the bolt, not directly on it) get a single jack (small sledge) & smack it hard a couple times (I'm assuming the thread side of bolt is sticking out enough to hit it)
    Edit: Forget the heat if your trying to salvage the rubber bushings
    Shit edit again, you got it Nice !!
  16. May 18, 2011 at 8:30 PM
    NegroTundra
    Land of Enchantment
    Okay new question
    Got everything on, went to tighten the shock mount bolts (the lower ones that attach to the u-bolt plate) and over torqued one of them. Busted the head right off the bolt.:frusty: I managed to get the threaded portion out of the u-bolt-plate female end thank god (2.5 hours later....might have shoulda just bought a new u-bolt plate). Anyways, anybody know the specs on this bolt? I ran real quick to home depot and they dont have anything close to this thing, the threads are very fine. If I knew the thread pitch and so on I will have a head start with calling nut-n-bolt companies tomorrow. Thanks
  17. May 18, 2011 at 9:46 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    For some reason 65 ft.lbs comes to mind
  18. May 18, 2011 at 9:57 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    yeah I was surprised how little torque those bolts take.
    sorry OP, I have no idea what the specs are for the bolt. You may just have to take the other one into a specialty store and match it up.
  19. May 18, 2011 at 10:16 PM
    chvymechanic
    chvymechanic Well-Known Member
    Thomas
    New Hampshire
    04 Limited TRD Off Road 4x4 Xtra Cab
    Stuff and Thangs
    1st gens are 90 ft lbs on the u-bolts.
  20. May 18, 2011 at 10:16 PM
    NegroTundra
    Land of Enchantment
    Steve O.....I see your from (or partially) the ABQ area...any recommendations?
