Leaf Spring Issues ALL PRO EXP
Discussion in 'Suspension' started by Vali, Feb 12, 2012.
  1. Feb 12, 2012 at 11:49 AM
    Vali
    Vali [OP] Well-Known Member
    Vali
    New Mexico
    4x4
    Hey guys so I'm in the middle of putting an All pro exp. leaf pack,
    Got it all torn down and I can't get the front pins out:confused:
    Any thoughts:ohsnap:
  2. Feb 12, 2012 at 6:02 PM
    pAP
    pAP ==========
    NJ
    11 Tacoma SR5
    ARB locker and OBA, All Pro front & rear bumper, All Pro IFS skid & modified t-case skid, Custom Trans Skid., 4x Innovations sliders, Custom tire carrier/bed bars, Warn Winch, Fox 2.5" Front coilover, Walker Evans 2.5" rear Shock, All pro Leaf, All Pro U-bolt flip, Baja Designs lights, PIA 510 lights, TRD exhaust cut back, Doug Thorley Pipe Bomb
    You're talking about the bolts that hold the front and rear of the leafs in? If so, did you take the back pins out from the shackles first? Makes it easier doing it that way first.
  3. Feb 14, 2012 at 7:23 AM
    Vali
    Vali
    New Mexico
    4x4
    :rant: Yea! they are out and I'm carrying the weight of the spring with a jack.
    after research I'm seeing some guys have had to cut them out.:frusty:
  4. Feb 14, 2012 at 7:39 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    PB Blaster and a big ass breaker bar (assuming an impact gun isn't doing the trick).
  5. Feb 14, 2012 at 10:19 AM
    Vali
    Vali
    New Mexico
    4x4
    :mad:Yea tried it
    Think I'm gonna just chop em off:cool:
  6. Feb 14, 2012 at 10:23 AM
    Pugga
    Massachusetts
    Try some heat (if the new leaf pack as new bushings). It might at least save the bolt.
  7. Feb 14, 2012 at 10:23 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    this or you will have to cut them out
  8. Feb 14, 2012 at 1:51 PM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    turn the bolt with a wrench or impact when you remove the nut.. should free it up. take all load off the springs also
