Leaf spring lifts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMan990, Apr 16, 2018.
  1. Apr 16, 2018 at 3:39 PM
    TacoMan990
    TacoMan990 [OP] Member
    Dustin
    2009 Barcelona Red Tacoma TRD
    With truck lifts that include leaf springs, do you add or replace the original ones to your Tacoma?
  2. Apr 16, 2018 at 3:40 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    if its an aal or ADD A LEAF then you undo the centering pin and add to the pack. blocks go under the pack, and leaf packs are a full replacement.
  3. Apr 16, 2018 at 3:53 PM
    TacoMan990
    Dustin
    MurderedTacoV2 What kind of lift did you put onto your Taco?
  4. Apr 16, 2018 at 4:50 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Bilstein 5100's with Old Man Emu 884's up front with a 2" Add A Leaf in the rear with Old man emu shocks. If i could do it again i wouldve saved up a bit more and went Old man Emu shocks in the front as well as the rear and used their 885 coil for half an inch of more lift. As for a future full leaf pack replacement, dakars are like 400$ so im putting those off for a bit as the Add a leaf still holds up just fine. So to lift my taco 2.25 ish inches it cost me about 650$ if you added in my 3" extended brake lines.
