Leaf spring question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RBTaco, Mar 29, 2016.
  1. Mar 29, 2016 at 3:34 AM
    RBTaco
    RBTaco [OP] Well-Known Member
    2013 RC 4X4
    Trac rac, tow hitch, fog lights, tonneau cover, Texas Edition rims, custom console, weathertech floor mats.
    Hey folks. Been searching this and can't seem to find an answer. I have a 2013 4x4 Reg cab. The leaf springs are a three spring pack. Is this the same 3 spring pack that has failed on numerous trucks? It seems to me that with a very small load the springs flatten right out. I do tow a 2000 pound camper with a 230 lb tongue weight which also squats it down pretty good too. I've been looking into getting some Firestone airbags but should I think about changing the springs first? Is there anything that Toyota would do for this as I've seen there is a tsb and also a recall but I don't believe that my truck is covered by those. Any info or recommendations are greatly appreciated. Thanks.
  2. Mar 29, 2016 at 3:41 AM
    gmann1972
    gmann1972 Well-Known Member
    Greg
    Rhode Island
    2013 tacoma SR5 DCSB
    You think your truck squats with only 230lb tongue weight and a 2000lb trailer. I tow a 5000LB trailer with a tongue weight of 600LB...now that's squatting...I just installed air bags, so hopefully that will help...
  3. Mar 29, 2016 at 4:33 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Air bags
  4. Mar 29, 2016 at 6:44 AM
    Pigpen
    Dan
    Northwest Montana
    I've been running Firestone bags for a couple years now. If you do anything that even resembles offroading, I suggest the Daystar airbag cradles. I'm still on the 3 leaf pack with zero problems. I'll eventually get an aftermarket leaf pack, but for now I just lift the rear of the truck with air to match the lift up front - as well as the load in back. My camper is a 1958, so she's got some weight to her, and there's always at least 400 pounds in the bed - probably over 500 when the winch is back there.
    Upgrade your rear shocks too. Mine went fast with the airbags forcing them to work harder. My OME N182s make for a smooth ride, it was bumpy and shitty with stock shocks.
  5. Mar 29, 2016 at 6:53 AM
    Yamaha_TacoR1
    Yamaha_TacoR1 Very slow racer
    NJ/NY, USA
    2015 Black TRD Sport 4x4 Limo
    - 5100/885's, 5100/Icon 3leaf progressive AAL with overload left in, 1/4" Taco lean spacer - ARE Z Series camper shell with Yakima rack system - Tepui Ayer Rooftop Tent - Prinsu Design Cabrac with heavy duty anadized bars - WeatherTech window deflectors/floor liners/bug deflector - Ultragauge MX1.3 - PopnLock codable locking tailgate handle - TRD shift knob - 3M tint - Extang solid fold2.0 tonneu cover - OEM Tacoma muffler tip - OEM Tacoma side steps - OEM Tacoma bed mat - OEM Tacoma roof rack - OEM TRD PRO front grille in matte black - OEM TRD PRO headlights - Fastway FLASH "Solid-Tow" adjustable aluminum ball mount hitch - Reese dual hitch ball covers - Masterlock locking J pin - GoPro windshield mount - Door trim protectors - Side mirror 'fish eyes' - Thule T2 hitch mount 2 bike carrier - LEDs: Map/Dome, 3rd brake, license plate, parking lights, reverse CREE's - SEMA TRD PRO 17" black matte wheels - 265/70/17 BFG A/T KO2s - Black Widow 40" x 95" 3 piece powder-coated folding bed ramp - Mobtown Offroad ribbed tailgate reinforcement skin - GRIDiT center console organizer - Salex center console organizer - Marco Extreme Blast black premium train air horn - 'ImmrYo' Rearview mirror relocate bracket - Mattgecko's Sliding window security bar - Rigid tow rear hitch shackle - Plasti-dipped gunmetal emblems - Blacked out ACEkraut's front license plate relocate bracket - De-flapped (OEM mud flaps gone) - Uniden XL520 CB Radio - Shmellmopwho's CB antenna bed mount - 3ft Firestik II CB antenna - BirdDawg Industries Tech Deck Extreme version w/ 3 Ram 1" ball mounts - Ram Mounts: iPhone6/iPad Mini4 X Grips with 1" dual ball sockets - Garmin GLO portable GPS & GLONASS receiver - Depo LED tail lights with blacked-out inner housing - Various Velcro backed patches on the headliner - 3D-Cell LED Maglite mounted to the driver seat - 4XInnovation DOM weld on sliders with kickouts (welded at 20degree angle) - 4XInnovation Hi Lift bed mounting system - Hi Lift All cast 60" jack with optional handle holder - Lotus Development Hi Lift slider adapter - Relentless Fabrifacfions dual bed rail mounts with dual Quick Fists - Salex glovebox organizer system - YETI vintage bottle opener mounted to the bed - TRD Sport style aftermarket epoxy resin decals for WT front mats - Rigid Industries LED D2 spot lights (Midnight edition) - CBI spot light hood mounts - Air on Board "Zombie Lights" switch - Rebadged WeatherTech floor liners with custom TRD Sport emblems - GoPro Hero 3+ windshield mounted - Mattgecko's cool white LED bedlight kit v2 - 1.25" Spidertrax wheel spacers - Maxsa Escaper Buddy traction boards (mounted on top of Prinsu Cabrac) - 42" Plano Weatherproof gun case (mounted on top of Prinsu Cabrac) - 2gal Rotopax gasoline can, mounting plate, DLX pack mount (mounted on top of Prinsu Cabrac) - Bestek 150W power inverter DC 12V to 110 V - DBPower 600A car jump starter/booster - SOS Off-road Concepts Factory recovery replacement mount - ARB 30' Recovery strap - ARB EZDeflator - Smittybilt receiver hitch D ring with 3/3" shackle - Bosch Icon wiper blades - RCI IFS steel skid plate - Trasharoo trash bag - mounted on tailgate - Lamin X yellow fog lamp covers - Aftermarket illuminated air conditioning/heater/vent knobs - Toyota full frame replacement - Spring 2023 ================================ Future mods: - Rear diff breather relocate - Foglights anytime - Install external speaker for CB - Install mattgecko bedlight kit
    I am also debating between air bags with daystar cradles or the dakar heavy duty leaf pack. I tow and haul my race bikes and cannot stand the bro lean.
  6. Mar 29, 2016 at 7:50 AM
    ColoradoTom
    ColoradoTom Team Velveeta™
    Colorado
    2014 Tacoma 4x4 Access Cab
    Yep, me too.
    I went through the 'need heavier duty rear suspension' thing 10 years ago with my T100 when I got a trailer. The mechanic I've been going to for nearly 20 years told me that airbags were absolutely the right solution for me for the T100. I had asked him "AAL or new leaf springs".
    I got off the phone with him 10 minutes ago. I told him about my 600-800 lb load with trailer attached and asked him, "air bags, add-a-leaf, or new leaf pack." He immediately said that Tacomas have terrible stock leaf packs and I should do that. He likes a local mfger, Rocky Mountain Spring and Suspension, so right now he's calling them for a quote.
    So, it looks like I'm going leaf pack.
    If by the bro lean you mean over to one side, air bags I think will do more to solve that.
    BTW, I know everybody loves the Dakar springs, but a friend of mine told me he was a little disappointed in how well they handled heavy loads. Just one data point.
  7. Mar 29, 2016 at 7:53 AM
    Yamaha_TacoR1
    NJ/NY, USA
    Let me know how much you get quoted for that leaf pack from Rocky Mountain suspension. I am interested in other options as well since from others' feedback, dakar packs are very stiff and clunk when going over bumps etc.
    Bro lean is when your front end sits a lot higher than the rear
    ColoradoTom[QUOTED] likes this.
  8. Mar 29, 2016 at 8:47 AM
    ColoradoTom
    Colorado
    My guy just called back. Apparently Rocky Mountain doesn't manufacture springs for my truck, they resell some others that they think are great. $1000 just for the parts, before any freight or installation, and that's with a good guy wholesale discount my mechanic would get.
    That's more than I'm willing to spend right now. Going to shop some other springs. SD Truck Springs has an airlift air bag kit on sale for 225. Wondering if the stock leaf pack would be OK with the support of the helper bags. I'd rather replace the leaf packs, but I just bought a $8K trailer. Would rather keep my rear suspension mod under 800. My wallet hurts.
    Suggestions for leaf packs that won't substantially lift the rear over stock (inch or two OK), will be good enough to be worth the expense of swapping them, but won't be $500 a side?
    Yamaha_TacoR1[QUOTED] likes this.
  9. Mar 29, 2016 at 9:08 AM
    RBTaco
    2013 RC 4X4
    Thanks for the suggestions. I think then that airbags will be my solution. It's funny how little weight it takes to flatten these.
  10. Mar 29, 2016 at 9:37 AM
    ColoradoTom
    Colorado
    Looking to me like the WHEELER’S 5 LEAF HD REAR SPRING SET is the deal for me. $500. Seems like nobody is trashing them on tacomaworld. The description "This is a heavy duty rear leaf spring set for owners wanting a stouter rear spring set for their Tacoma. Great for trucks hauling extra weight, utility and expedition applications" sounds like exactly what I wanted.
  11. Mar 29, 2016 at 9:58 AM
    Yamaha_TacoR1
    NJ/NY, USA
    Wow $1k? That is too steep for my blood. Check out Wheeler's hd leaf pack and Dakar from OME. Both are waayyyy below $1000. Good luck.\
    EDIT: Nevermind on the wheelers pack you already found it. Check out OME Dakar though
  12. Mar 30, 2016 at 9:06 AM
    ColoradoTom
    Colorado
    Just ordered the Wheeler 5-leaf HD. With shipping it's going to be close to $650. But I feel good about it being a good fit for my needs and looks like a quality product. I had checked out the OME Dakars. Friend who raves about OME actually said that he was not so impressed by their load-carrying. See lots of people on taco-world who got Wheeler packs who are pleased.
    Will post to this thread with my impressions.
  13. Mar 30, 2016 at 9:09 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I regularly have 800-1100 lbs in the bed of my truck and my Dakars are flawless, and I'm not carrying it across the highway, I'm on the freeway for 45 miles and then running another 12 miles through a busy downtown area before I unload.
    Couldn't ask for a better rear setup.
    ChadsPride likes this.
  14. Mar 30, 2016 at 9:46 AM
    Pigpen
    Dan
    Northwest Montana
    A new leaf pack would have been a better solution for my uses at this point, with constant weight in the truck. When I got them, I drove around with an empty bed most of the time. Being able to adjust the air pressure for weight worked great for me at the time - no rough ride when unloaded. I'll upgrade eventually.
  15. Mar 30, 2016 at 9:49 AM
    ColoradoTom
    Colorado
    I'm sure the Dakars are very good. Also don't want that much lift. Planning to leave my front end stock. Wheelers are 1.5" over stock.
  16. Mar 30, 2016 at 9:51 AM
    T4RFTMFW
    I've heard good things about the 5 pack.
    I ran their 1.5 progressive 3 leaf AAL for a few months also with my first lift setup and had no issues either, they just didn't handle weight any better than the bare OEM leaf packs did and I lost most of the lift when my shell got installed (220 lbs).
  17. Mar 30, 2016 at 9:56 AM
    ColoradoTom
    Colorado
    Bummer. Yeah, I got the 5 leaf (4 + overload) HD pack. Called and talked to Dan, he thought they should be perfect for my needs. Hoping for the best.
    Expensive spring for me so far, this camper adventure is going to be close to 10K by the time I get done! But the leaf pack is I think a good investment for a truck I intend to keep for a while.
  18. Mar 30, 2016 at 9:57 AM
    T4RFTMFW
    Hope so. Post pics when it's thrown on.. seems like the 5 pack info on here is fairly sparse.
  19. Mar 30, 2016 at 9:59 AM
    Dajeepman
    Dajeepman Well-Known Member
    Andrew
    Pittsburg , Tx
    2006 Gold Tacoma base 4x4
    Thats a lot of weight for these little trucks.
  20. Mar 30, 2016 at 10:51 AM
    RBTaco
    2013 RC 4X4
    I don't think 2000 lbs trailer with a 230 lb tongue weight is too much. I agree a 600 lb tongue weight is another story. Truck is rated for a 1300 lb payload or something like that. I do like the idea of a more substantial leaf pack. I think I'm gonna look around at some of the ones mentioned in this thread. Just the weight of my tracrac, hitch, bedmat and mobtown tailgate cap and my springs are flat. I can't imagine that's more than 150 tops.
