Leaf spring recall again
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AZM9, Mar 21, 2017.
  1. Mar 21, 2017 at 6:15 PM
    AZM9
    AZM9 [OP] Well-Known Member
    Jay
    Chandler, AZ
    2009 Prerunner TRD Sport
    ARE tonneau cover, Redline hood struts, Leaf TSB, and Trans TSB, Satoshi grille.
    My truck had it done back in 2009 when it had around 10K now Toyota wants to do it again and it has 94K on it. Ok with me but it will take time to settle again. I haven't had any problems. Has anyone else had to do a second recall on their springs.
  2. Mar 21, 2017 at 6:16 PM
    TRDRon14
    TRDRon14 Active Member
    WV
    2014 Pyrite Tacoma TRD Sport
    Do you know what year range?
  3. Mar 21, 2017 at 8:08 PM
    AZM9
    Jay
    Chandler, AZ
    No, I don't. My service advisor just told me that it is a current recall that's open. I imagine it's for all 2nd Gen.
  4. Mar 21, 2017 at 8:11 PM
    TRDRon14
    WV
    I'll check it out. Thanks!
  5. Mar 21, 2017 at 8:30 PM
    TacoLV
    TacoLV Active Member
    Nick
    Vegas
    2008 PreRunner
    Maxtrac 4' , AAL
    I just called my Toyota dealer here today about the recall , dont know if it was ever done on my 08'. Service rep said the springs are on national backorder, no telling when they would be in. A month, 3 months maybe 8. Just put me on list for when they do come in.
  6. Mar 21, 2017 at 8:55 PM
    AZM9
    Jay
    Chandler, AZ
    My Service Advisor called me today and suggested I get it done tomorrow because they just got a load of springs in today. Otherwise, I may have to wait because of the backorder.
  7. Mar 21, 2017 at 8:58 PM
    Pigpen
    Dan
    Northwest Montana
    Just say no and get real leaf springs.
    spiralout462, smcgill and Silverspool like this.
  8. Mar 21, 2017 at 9:00 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    If you are OK with the stock springs take them up on the offer. Fresh springs. One reason they are recalled is because they can break and puncture the gas tank. Probably happened to one guy but hey.
    AZM9[OP] likes this.
  9. Mar 21, 2017 at 10:03 PM
    AZM9
    Jay
    Chandler, AZ
    Exactly what he told me. I'm ok with anything new they want to give me. The stock springs have been fine for me so far. I have a heavy tonneau on the back so that will weigh them down a tad. I put 5100's up front for leveling.
  10. Mar 21, 2017 at 10:05 PM
    IronPeak
    AuggieX
    Back to Back
    Im sure you know this but with even a small load like that your springs aren't performing like they did when new. Guess it's a little inconvenience but maybe you could schedule it when you are getting your 90k service or something
  11. Mar 21, 2017 at 10:18 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    The new springs have additional clips to prevent spring shift if a spring breaks. Go ahead and get them if you don't plan to upgrade from stock. When they did mine, it included new bumpstops also.
  12. Mar 21, 2017 at 11:19 PM
    AZM9
    Jay
    Chandler, AZ
    I did schedule my 90k service and he suggested to do the springs at the same time.
  13. Mar 22, 2017 at 9:05 AM
    baboon
    baboon Active Member
    The first one wasn't a recall, it was a service bulletin. The service bulletin changed it from 2+1 to 3+1 leaves.
    Like somebody said above, the recall is about the extra clips that hold it together. The new springs aren't any "better", except that when they break, they will remain in line instead of cutting into your gas tank.
  14. Mar 22, 2017 at 9:22 AM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    I would have to tell them where to stick their springs! If you want new and better you're gonna have to pay for it. Worth very penny in my opinion.
  15. Mar 22, 2017 at 9:32 AM
    baboon
    Even so, it is probably still a good idea to take it in and get a free set of brand new OEM springs that you can sell for a few hundred on craigslist.
  16. Mar 22, 2017 at 9:37 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Not just that but let the dealer take the old ones off and put new hardware so if you then upgrade you won't have old/seized parts.
  17. Mar 22, 2017 at 10:00 AM
    orezona
    orezona title unspecified
    satan's skillet
    2006 TRD OR DCSB OMGWTFBBQ TL;DR
    WARRANTY VOIDED
    I know it's been addressed ad neaseum but when you have a lift that includes aluminum blocks on your springs doesn't the dealership look at you funny and then laugh when you ask them if they can do the recall with the aftermarket mod done?
    "Asking for a friend"
  18. Mar 22, 2017 at 10:03 AM
    baboon
    That really would depend on the dealer.
    Of course, if you had aluminum block lift on leaf springs, **I** would look at you funny.
  19. Mar 22, 2017 at 10:14 AM
    orezona
    satan's skillet
    WARRANTY VOIDED
    Okay, got it.
    Also,
