Leaf spring recall replacement height
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DanoDavis, Apr 10, 2017.
  1. Apr 10, 2017 at 7:51 AM
    DanoDavis
    DanoDavis [OP] Alright meow
    Daniel
    Allen Tx
    09 Double Cab 4x4 6-Speed V6
    1 1/2" lift with 5100's, custom exhaust, LT Headers, URD CAI, URD MAF Calibrator, Electric fan, Camper shell, retrofit projectors, and other goodies..
    So, this Thursday in dropping my truck off to have the recalled leaf springs replaced, the steering wheel recall done, and for them to inspect my frame.
    My question is this:
    Do these replacement leaf packs cause the truck to ride any higher than stock? I've currently got some add a leafs in the back, that gave me about 2" of lift.
    Too high for my liking, but I just kept them in. Now that they're all getting torn out, I'm curious if I should order some new add a leafs.
    Looking for 1 to 1.5" of lift.
    If these new leaf packs that they're going to install will net me that, then I'll just leave them be.
    Anyone able to confirm?
  2. Apr 10, 2017 at 7:54 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    when mine was done, the leafs were completely flat. i had a 1.5" AAL previously, but that wouldn't cause the new ones to be flat when they went on and for the rear to be lower than 1.5" difference. local toyota dealer tried to say the flat leaf packs were how they were supposed to be.
    not saying that will be the typical experience.
  3. Apr 10, 2017 at 8:13 AM
    ajpagosa
    ajpagosa Well-Known Member
    SW Colorado
    2005 Access Cab TRD Off Road 6-speed manual
    I just had the TSB leafs put in a 2005 TRD OR a month or two ago. Got about 1.5" over where the old originals were and it drove and looked odd, in an ass-high way. Have since put on 6112/5160 with 6112 set at #2, levels it out perfectly. So in my truck's case at least, there was a lift from the TSB 4 leaf over the old 3 leaf. My truck had ~75k miles.
  4. Apr 10, 2017 at 8:29 AM
    JTM1
    JTM1 Well-Known Member
    Justin
    West Houston
    99 PreRunner, 08 TRD OR DC, 16 TRD OR DC, 18 F150 FX4 5.0L
    99-Fabtech Lift, Fox coil overs, OME Dakar leaf pack, LCE Header and Pro Flow Exhaust, TRD Supercharger, 275/70-17 BFG AT KO 08-Bilstein 5100s, OME 885 Coils, Wheeler's 2"AAL, All-Pro Skid Plates, Shrockworks Sliders, 265/75-16 BFG AT KO2 16-Daystar Strut Spacer, SSO Slimline Hybrid Winch Bumper, All-Pro Skid Plates, Shrockworks Sliders
    I had to go back and look at the pictures, but I think the TSB pack was flatter than OE pack.
  5. Apr 11, 2017 at 5:51 AM
    DanoDavis
    Daniel
    Allen Tx
    So has anyone added an add a leaf to the new leaf packs?
    The new packs are 4-leaf, right?
    Don't really want to make it a 5-leaf I suppose, might right stiff.. just trying to gauge, I guess.
    Trying to have as little down time as possible, as I've got a couple days off this weekend, so if I need to add a leaf, or whatever, I'd like to do it then.
    Don't wanna be driving around looking like a dog dragging it's butt on the carpet LOL
  6. Apr 11, 2017 at 6:38 AM
    The_Hodge
    SC
    i got my hands on another 3 leaf pack and added my 3 leaf progressive AAL.
    DanoDavis[OP] likes this.
  7. Apr 11, 2017 at 7:34 AM
    DanoDavis
    Daniel
    Allen Tx
    So you're running 6 leafs?
    What's your net lift now?
  8. Apr 11, 2017 at 7:36 AM
    The_Hodge
    SC
    the 3 leaf aal is 1.5". also running a small 1" block. may upgrade to a full leaf pack later to get 2.5" w/o needing the block.
  9. Apr 11, 2017 at 8:19 AM
    DanoDavis
    Daniel
    Allen Tx
    Any suggestions on AAL for this TSB leaf pack?
    Got a 6 month old kiddo, so trying to keep spending to a minimum, otherwise I'd probably sell the TSB pack, and buy a new leaf kit.
  10. Apr 11, 2017 at 8:28 AM
    JTM1
    Justin
    West Houston
    I installed a Wheeler's 2" AAL and a set of OME 885 coils a week after the TSB springs were installed. The number of springs has no effect on the harshness or stiffness of the ride, so you shouldn't worry about it becoming a 5 leaf or 7 leaf pack.
    If you don't regularly tow or haul heavy loads I'd get a multi-leaf progressive AAL, they have a soft spring rate.
  11. Apr 11, 2017 at 9:17 AM
    DanoDavis
    Daniel
    Allen Tx
    I've got a 5x8 enclosed trailer that's full of tools and supplies. Probably about 1500lbs, plus another 200 lbs worth of crap in the bed, plus a camper shell.
    I definitely need something to hold some weight, but also not kill empty-weight ride quality.
    We do more road tripping in this truck, than my wife's Civic.
  12. Apr 11, 2017 at 9:20 AM
    DanoDavis
    Daniel
    Allen Tx
    Also, only looking for about 1.5" of lift.
  13. Apr 11, 2017 at 9:59 AM
    MTyota
    MTyota Well-Known Member
    Bozeman, MT
    05 Tacoma 2.7 5spd SR5 4x4
    ABS switch, tailgate lock, factory fogs, tonnopro loroll, icharger aux cable, 10mm hex oil plug swaps
    Im getting mine done as soon as the stealership has the right shackles.
    From the research i have done for moderate offroad use i am going with
    5100s all around
    Wheelers 1.5 proggressive aal (with oem overload spring)
    OME 2885 coils
    Hoping for about 1.75" from stock which on my 05 2.7L should be about 2" from where it is now.
  14. Apr 11, 2017 at 10:51 AM
    JTM1
    Justin
    West Houston
    I'd just get a standard, single leaf, 1.5" AAL then.
    DanoDavis[QUOTED][OP] likes this.
  15. May 3, 2017 at 4:02 PM
    WTtoolman
    WTtoolman Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    Dano, did you decide on which add-a-leaf? I just got my frame replaced, with the updated leaf springs, and am looking for the same thing.
  16. May 3, 2017 at 5:02 PM
    bgsmith
    bgsmith Well-Known Member
    Brian
    Hingham, MA
    06 Speedway Blue TRD Sport 4x4 DCSB
    ATX Mojaves with 265/75 16 Hankook Dynapro ATMs, Spidertrax 1.25" spacers (front and rear), Bilstein 5100 all around up front set at 1.75", Blacked out badges, Pioneer AVIC D3 DVD/NAV Head Unit, K&N Air Filter, Tyger Tri Fold Tonneau Cover, Rockford Fosgate Punch Speakers.
    My truck sagged after I got the TSB leaf packs, added a Deavers AAL, non ALL is above, with the AAL is below.
  17. May 3, 2017 at 7:22 PM
    WTtoolman
    William
    Omaha, NE
    What lift do you have up front, BG? How much lift was your AAL supposed to provide? Is your Deavers AAL the ones that Wheelers sells in either 1.5", or 2" varieties? I had a Deavers 2" AAL for about 4 years. When I got my frame replaced I was mad that they didn't install the AAL from the old leaf pack like they agreed to. Come to find out, half of the driver's side AAL had broken off at sometime and I had no idea.
  18. May 3, 2017 at 7:31 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    I'd get wheelers 5 leaf pack or Icon/Wheelers 3 leaf progressive add-a-leaf.
  19. May 3, 2017 at 8:35 PM
    bgsmith
    Brian
    Hingham, MA
    In the top pick I have 5100s and stock coils set at 1.75, nothing in the rear (5100s with TSB leaf packs)
    In the bottom pic I have 5100s with OME 884 coils at the bottom setting, the Deavers AAL is from Headstrong Off-road and is supposed to give 1.5-2" of lift.
  20. May 3, 2017 at 9:39 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    On my truck, the TSB leafs with a Wheelers 3 leaf HD add a leaf (1.5") sat level with 5100s up front set at .85 with Eibach springs and 1/4" top plates.
    When it had the non TSB spring with the same add a leaf, the truck sat level with the 5100s and Eibach springs, sans the top plates.
    The TSB vs non TSB springs on my truck netted about 1/2" of lift. The non TSB springs were still in good shape and had some arch to them still. I had a picture of them side by side, but cant find it.
    I added 1/2" blocks to the rear of the current set up and the truck has the factory rake to it again.
    The leaf pack has 7 leafs and rides really well. Its not overly stiff nor does the rear end hop around.
