Leaf spring remedy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by VA Tacoma, Mar 29, 2016.
  1. Mar 29, 2016 at 5:02 PM
    VA Tacoma
    VA Tacoma [OP] Well-Known Member
    Frank
    Roanoke, VA
    08 AC 4x4 SR5 off road 4.0 super white
    bone stock
    yesterday I received a letter from Toyota stating they had a remedy and to call my local dealer for an appointment. Curious to see how it turns out.
  2. Mar 29, 2016 at 5:07 PM
    devkurf
    devkurf Member at Large
    midwest
    I think they inspect your old leafs and if they fail they replace them. If they pass the inspection they spray them with leaf fluid film. I could be wrong.
  3. Mar 29, 2016 at 5:33 PM
    Bob2
    Bob2 Member
    Bob
    07 Tacoma
    I got the recall last summer 2 months after they broke and I replaced them
  4. Mar 31, 2016 at 5:50 AM
    VA Tacoma
    Frank
    Roanoke, VA
    bone stock
    Dealer made appointment for May 6. Said must replace 3 leaf springs, which I have. On 4 leaf, they inspect then replace if necessary.
  5. Mar 31, 2016 at 6:20 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    They will inspect for broken leafs, inspect frame? Even the 4 leaf packs are being swapped out I believe. If you have receipts for previous work done due to broken springs, Toyota will reimburse you.
  6. Mar 31, 2016 at 10:10 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    From what I understand, if you still have the original 3 leaf springs those will definitely get replaced. If you have newer, 4 leaf you may or may not pass inspection depending on the brackets locations. The brand new ones still suck big time, mine is only a few weeks old and they still sag with 120lbs in the rear.
  7. Apr 1, 2016 at 3:00 AM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    I took mine in yesterday for the inspection, I have the three leaf / three clip leaf packs, and was told they need to be replaced. Dealership said it would take about a week or two before they come in. There were about 6 other older model 2nd Gen Tacos in the service area, all there for the same thing I'm sure.
  8. Apr 1, 2016 at 3:51 AM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    That's a lot better than 1 of the dealers I took mine to, they told me 6 to 8 weeks.
  9. Apr 1, 2016 at 3:54 AM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    To all that replaced before recall.Call Toyota care and they will give you a case # .then you get reimbursement.Must have receipt!!! Call 1-800-331-4331.Must have vin# ready to go.Just sent my paper work in.Good luck to all.
