Leaf spring shackle knock
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Mar 10, 2025.
  1. Mar 10, 2025 at 10:08 AM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    I have looked this up on the site & see various suggestions regarding the shackle bolt/sleeve/lube. However, I am wondering if the rebound clip I’m using is causing an issue. My springs are a mix of leaves off two sets of springs, some I cut, some original length, plus an aal. Because the aal’s have no pre-drilled holes & I don’t have a drill press, I used these. They do seem more restrictive than the stock ones.
    https://www.amazon.com/Stainless-Together-Vehicles-Stabilizing-Control/dp/B0DNLSYHBR?crid=SLRKFZEGQHF1&dib=eyJ2IjoiMSJ9.Cd2olT9Ut15Dm8Xsv0oPB_qR5xn0q0LRzUJ-1ADiM8OWClOOMRY7b4qb_vjRQ5Me9K1kUaL2grG-TVrV2oOC1nZ022-ubhjOdXUWEF4TbxNS-bCjl8s889mLgoLAAwshX9ZuYWRbZ68Iprwl5vtJ5c6J_2E1jY2b_eQ1F3FK51yEfDgfiqeGxMa8eq2nYdnfeTkMiIE2eRD95wcOdQEV2w.vPqlK0Ybd7Wo7g32MxfNyE_8zMV9XdTvb94Lo1pf-mk&dib_tag=se&keywords=leaf+spring+rebound+clips&qid=1741625155&sprefix=leaf+sprung+re%2Caps%2C122&sr=8-7-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9waG9uZV9zZWFyY2hfbXRm
    This is the noise (vid below) I’m getting from the shackle. Course it is a lot more pronounced when driving, mostly over bumps). I can also see signs of potential side to side movement at the shackle to bracket (top) bolt. Might be worth mentioning that the left side is fine. Same setup except a different shackle. Stock, well, stock shape made by a local spring shop, on the right (problemed side), aftermarket on the left. Same length. & now that I look closer, the left does seem to be made of thicker steel.
    https://youtube.com/shorts/yQM4kqRkCTU?feature=shared
    So…. Shackle? Rebound clips? Something else? Is there any way to secure rebound clips if there are no holes?
  2. Mar 10, 2025 at 11:04 AM
    Kristi with a K
    Western MA
    I take back the thickness of the steel. Made no sense, so I actually measured. Deceiving in appearance. The “stock” one has studs though. Not thru bolts like the other.
