Leaf Spring Shackle Polyurethane Bushings *Solved*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoCasa, Jan 27, 2019.
  1. Jan 27, 2019 at 5:11 PM
    TacoCasa
    TacoCasa [OP] Well-Known Member
    Tim
    The 719
    2013 Black Tacoma OR DCSB
    Bilstein 6112/5160, Camburg UCAs, HD Dakars, Uni filter, diff breather relocated.
    Hey all,
    I am currently installing some OME Dakar (EL096R) HD leaf springs. I believe the bushing kit is from Energy Suspension. Like most without a press, I had a difficult time getting the old bushings out. It was also a bitch to get these new polyurethane bushings to be fitted in the leaf spring shackles. I managed to press the sleeve and bushings using the bottle jack and the weight of the truck. However, after fully pressing the bushings in, they tend to bulge out to a point where I cant seat them back on the truck.
    My wife had the idea to use the leaf spring bolt with several washers to tighten the bushings onto the shackle. After initially doing this, the bushing seems to sit right. However, after loosening the bolt, the bushings want to bulge out slightly again.
    We re-tightened the bolt back onto the bushings to "press" it for a longer period of time, hoping the bushings will remain fully seated.
    What are good ways to keep the bushings seated so I can fit the shackle back in place?
  2. Jan 27, 2019 at 8:25 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I think you are supposed to remove that metal sleeve, that is likely why they aren't sitting right
    Crom and EDDO like this.
  3. Jan 27, 2019 at 8:52 PM
    TacoCasa
    Tim
    The 719
    I'm not quite sure what you are referencing in the picture. To clarify what is going on, I used the leaf spring bolt with some washers to press the bushings and metal sleeve (not pictured) into the shackle. However, the bushings immediately start bulging out as soon as I relieve pressure from the bolt.
  4. Jan 27, 2019 at 9:07 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    The outer metal sleeves from the old bushings needed to be removed from the shackles prior to installing the new bushings.
    SilverSurfer likes this.
  5. Jan 27, 2019 at 9:20 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Crom and TacoCasa[OP] like this.
  6. Jan 27, 2019 at 9:21 PM
    TacoCasa
    Tim
    The 719
    Now that you mentioned it, I dont remember taking out an outer sleeve after I took out the bushings and inner sleeves. Although, I didnt see anything unusual in the shackle eyelet. Is there a special way to them out?
  7. Jan 27, 2019 at 9:23 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    That metal sleeve has to be chopped out. I just bought the naked shackles I posted above.
  8. Jan 27, 2019 at 9:49 PM
    TacoCasa
    Tim
    The 719
    Thanks for that input! I just assumed that these bushings were plug and play.
  9. Jan 27, 2019 at 10:48 PM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
  10. Jan 28, 2019 at 4:58 AM
    TacoCasa
    Tim
    The 719
    @gotblika thanks for that post! For some reason, I have seen this post a while before conducting my install. Everything seemed gibberish to me, until I've actually worked with the part. Looks to me that @EDDO helped me figure this out by looking at a stock shackle and compared mine with it.
    Getting that flange out looks like it sucks. Either I haven't done enough research, failed to comprehend the instructions, or both.
    Anyways, thanks all!
    EDDO likes this.
  11. Jan 28, 2019 at 8:35 AM
    gotblika
    Maui
    2015 DCLB Sport 4X4
    @EDDO That shackles come in a pair right? For ~$20 I think that’s the way to go.
  12. Jan 28, 2019 at 9:07 AM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    They’re $20 each. Sold individually.
  13. Jan 28, 2019 at 9:38 AM
    gotblika
    Maui
    2015 DCLB Sport 4X4
    Ahh ok... by them calling it a kit I thought it’d be a pair.
  14. Jan 28, 2019 at 1:43 PM
    gotblika
    Maui
    2015 DCLB Sport 4X4
    according to the recall, should be 2 shackles in the kit.
  15. Oct 2, 2020 at 10:46 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I know this is an old thread but I jut ordered these. I put quantity as “2” and I got 4 shackles. So yea they come as a kit for anyone else that stumbles across this thread
    Crom, TireFire and EDDO like this.
  16. Sep 10, 2021 at 3:11 PM
    marcotheviking
    marcotheviking Member
    Marco
    Los Angeles, CA
    2013 Tacoma TRD Sport
    Hey guys, reviving this thread if anyone can clarify that would be cool.
    In the process of putting Dakar’s on my 2013 TRD Sport and want to get new shackles on there but some Toyota dealer sites are stating that PN 04005-65104 does not fit my Taco. Can anyone confirm? From the image @EDDO provided they look the same as the ones on my taco.
    thanks in advance!
  17. Sep 10, 2021 at 5:05 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    That’s the part number I have on my 2013. Should be fine.
  18. Sep 10, 2021 at 6:28 PM
    marcotheviking
    Marco
    Los Angeles, CA
    kickass, just ordered mine. Thanks!!
    EDDO[QUOTED] likes this.
