Leaf spring shims
Discussion in '1st Gen. Tacomas (1995-2004)' started by MK ULTRA, Sep 5, 2015.
  1. Sep 5, 2015 at 9:20 AM
    MK ULTRA
    MK ULTRA [OP] Well-Known Member
    JIM
    Huntsville Ala
    4X4
    Are leaf spring angle shims to get your differential in line with the drive shaft or is it to get the drive shaft in line with the carrier bearing?
    I just installed some Dekars and the drive shaft and rear end are in line perfect. The drive shaft does an angle sum with the carrier bearing. Thanks would have done a search but my phone won't search on this site
  2. Sep 5, 2015 at 8:47 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Diff to drive line.
    To correct the carrier you drop it down a bit with spacers.
  3. Sep 6, 2015 at 10:14 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Axle shims are for correcting/aligning the relative angle from the yoke/flange off the rear diff to the drive shaft's rear U joint (where it bolts together) As mentioned, if vibes occur in the carrier bearing, alignment is usually done with a CB drop kit or spacers (they both achieve the same thing)
