Leaf spring sizes
Discussion in '1st Gen. Tacomas (1995-2004)' started by Deepsnow, Jul 20, 2022.
  1. Jul 20, 2022 at 8:16 PM
    Deepsnow
    Deepsnow [OP] Member
    Do all Tacomas from 1998-2004 have the same size of leaf springs
  2. Jul 20, 2022 at 10:40 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    All six-lug Tacomas (4wd/Prerunner) '98-04 do have the same size leafs. '95.5-'97 are shorter.
    5-lug Tacomas don't share the same rear leaf setup with 6-lug at all.
    MalinoisDad and Black DOG Lila like this.
  3. Jul 21, 2022 at 6:10 AM
    Deepsnow
    Will a single cab be the same as the extended cab ? They are both 6 lug wheels
  4. Jul 21, 2022 at 6:51 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yes.
  5. Jul 21, 2022 at 7:50 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Yes.
    You can find out about a bunch of leaf spring options, here, as well, since generally used leaf springs off any Taco are likely to be... lackluster.
    Replacing Leaf Springs on a Tacoma
    Mr Yoda likes this.
  6. Jul 21, 2022 at 7:54 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Why did you leave out the 95-97 Dakar options, I ran them and they were pretty good
    CS018R for light duty and CS019R for heavy
    1997tacomav6 likes this.
  7. Jul 21, 2022 at 8:05 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Looked for them and couldn't find them (only found the 98+), so I didn't know they existed. I'll get them in there, since I know the Dakars in general are reasonably well liked.
  8. Jul 21, 2022 at 8:14 AM
    Burito2taco
    Burito2taco Active Member
    04 Tacoma
    Please share what you ending up using and how difficult was the swap
  9. Jul 21, 2022 at 8:46 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Replacement is easy and can be done within 3 hours by a first-timer.
    It only becomes a real problem if there's rust as unbolting turns to cutting. Reciprocating or sawzall is your friend here.
    That and penetrating fluid.
  10. Jul 21, 2022 at 9:24 AM
    Burito2taco
    04 Tacoma
    Great thanks for the heads up!
  11. Dec 18, 2022 at 5:02 AM
    1997tacomav6
    Denver
    Looking at getting these for my 97, CS018R
    did you run these?CS018R
    How much better are they over stock?
    How much did it raise the rear?
    Is the CS018R a 5 pack spring?
  12. Dec 18, 2022 at 6:51 AM
    Brahms
    Brahms Well-Known Member
    Houston, TX
    2004 Tacoma DCSB 4x4 SR5 V6 TRD
    I have to swap my springs because I installed them on the wrong side. Can I reuse my newish u-bolts?
  13. Dec 18, 2022 at 9:39 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Technically, you should not if you have already torqued them to spec. In practice, I (and others) have re-used u-bolts before.
    Personally, several factors weigh on the decision:
    * diameter of u-bolt - the larger the diameter, the less likelihood that they were torque-to-yeild
    * length of u-bolt - obviously, you want to be sure that they are long enough for the new leaf pack
    * difficulty of removal - if the nuts are hard to get off due to corrosion, mud, etc...
    * condition of threads (on bolts + nuts) after removal - if the nuts spin on/off the ubolt freely by hand, then there's a better chance that the threads aren't tweaked already
    It's a decision you'll need to make for yourself. Just remember - they aren't all that expensive (less than a tank of gas), so there's an easy argument to be made for "better safe than sorry" when it comes to using new u-bolts each time.
    Area51Runner likes this.
  14. Dec 18, 2022 at 1:01 PM
    Speedytech7
    I ran the CS019R packs. They're for extra cabs carrying over stock, they're a bit too light for what I carried though. CS018R is what they recommend for single cabs, but beware they lift more than they claim so you may have to pull a leaf or two. I forgot how many leaves are in them, maybe 5 or 7, I can probably dig a picture up.
    1997tacomav6[QUOTED] likes this.
