Leaf Spring TSB for a truck that's waaaay out of warranty
Discussion in 'Suspension' started by minibiter, Nov 22, 2012.
  1. Nov 22, 2012 at 2:39 PM
    minibiter
    minibiter [OP] New Member
    Virginia
    2007 Double Cab TRD Off Road
    Apologies in advance if this question's already been answered in another thread and I didn't find the answer. I looked, I promise!
    I have a stock 2007 double cab TRD off road and I need the back to be a little stiffer so it stops bottoming out while hauling my toys around. I've read all about the leaf spring TSB but with 160k miles on an 07, I'm not getting it for free.
    I want it to be a little stiffer, but not much higher. 1" max, 0.5" would be ideal. I'd like to avoid having to mod the front suspension to keep the ride even and ideally I'd like to keep the same shocks on the rear but obviously if the rear spring stiffness changes much I'll need a different damper to keep the ratio.
    So, any recommendations? Should I get an add-a-leaf? All-new leaf packs? What are good ones to get? What's worked for other people? Or should I just pay for the TSB?
    I'd like to keep it under $1000. Seems like that shouldn't be too hard from the little bit of shopping I did.
    Happy Thanksgiving!
  2. Nov 22, 2012 at 3:39 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    There are many possible solutions to your rear suspension problem. The one WRONG ANSWER would be to pay for Toyota TSB rear springs from a dealer. There are many better answers that are cheaper than the Toyota springs.
    At 160,000 miles, all four of your factory shocks are probably long overdue for replacement. Consider replacing them with Bilstein 4600s or 5100s, not theToyota Bilsteins that you have now. There is a big differnce in quality and performance.
  3. Nov 22, 2012 at 3:51 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    People sell the TSB leafs on here all the time. Buy a used set.
  4. Nov 22, 2012 at 3:52 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    As stated above do not pay a dealership for the TSB leaf packs. Depending on the current condition of your springs I would start with an AAL and new shocks and see where that gets you as long as the rear leafs haven't hit the negative arch stage. If you need a little more support but don't want to lift the vehicle then airbags may be an option.
  5. Nov 23, 2012 at 8:02 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Defroster mod, Bilstein 5100s front, Adjustable Ranchos rear.
  6. Nov 23, 2012 at 8:04 AM
    theredofshaw
    theredofshaw Well-Known Member
    Reno, NV
    2016 Honda Civic (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
  7. Nov 23, 2012 at 10:17 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    As mentioned, Toy OE products are not the way to go.
    Buy a set of 4 Bilstein 5100's, set the fronts at 0.
    For min lift in the rear, NWOR offers minimal lift.
    Putting add a leafs is only a bandaid.
    With Toyota, you need to start from scratch.
  8. Nov 23, 2012 at 10:33 AM
    Teniente
    Teniente Well-Known Member
    Carson City, NV/Ensenada, Baja California, MX
    White 2006 SR5 DCSB 4x4
    Had the same problem with my 2006 DC. put on new shocks but that didn't help. Installed a pair of Firestone Ride-Rite air springs (bags). No problems anymore. Got the no-drill model, went on in about 1 hour.
  9. Nov 23, 2012 at 12:40 PM
    minibiter
    Virginia
    Thanks - I'm thinking an add-a-leaf and Bilstein 5100's. Now to find the best Black Friday deal...
  10. Nov 23, 2012 at 12:42 PM
    Large
    Large Red
    Why aal when you have 1k to spend, buy a new leaf pack.
  11. Nov 23, 2012 at 12:54 PM
    dexterdog
    Oly WA
    2012 F150
    OP doesn't want a lift. Another option is to check and see if you have a spring shop near you. I have had good luck with a shop near me that does great work.
  12. Nov 23, 2012 at 3:35 PM
    thinkingman
    redmond WA
    NWOR doesn't lift and will do much more than AAL.
  13. Nov 23, 2012 at 5:14 PM
    dexterdog
    Oly WA
    2012 F150
    Cheaper to find a local solution.
