Leaf spring tsb
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trudavid2010, Sep 14, 2011.
  1. Sep 14, 2011 at 4:44 PM
    Trudavid2010
    Trudavid2010 [OP] Member
    David
    Indiana
    Tix pro dcsb
    None yet
    I bought my 2011 Tacoma tix trd on 9/06/11 and quickly found out how bad the rear end sags with any weight in the bed or a small trailer. So I went to the dealer this morning to find out about the tsb. They told me I had to make an appointment to have it looked at and then they would consult with Toyota. I quickly told them that would not work, I listed off the fixes in the tsb. The service manager quickly changed his tune and said let me call the local Toyota rep and get back to you. Well after about an hour and a half he called and said parts are on there way from Cali and would like to install first thing in the morning. So we will see how that goes tomorrow. I just hope I can talk them into installing the timbrens I bought since they will have it all apart.
    We see how it goes hopefully the ride does not get to bad.
  2. Sep 14, 2011 at 5:01 PM
    Trudavid2010
    David
    Indiana
    Tix pro dcsb
    None yet
    Why do you say the tsb sucks?
    I thought about air bags but I think they would be more of a pain to air up and down all the time. I am a general contractor pulling a small enclosed trailer everyday.
  3. Sep 14, 2011 at 7:25 PM
    ASE_MasterTech
    ASE_MasterTech Well-Known Member
    Monmouth County, NJ
    2010 TRD Sport DBL\Cab
    Wet Okole seat covers, Westin Platinum Oval tube steps, Rear spring TSB plus Super Springs, D-Rings in all bed bolts, Tailgate reinforcement mod (for loading Harley)
    The TSB '4 leaf spring' replacement is a definite improvement over stock.
    If you need more after that, add a set of Super Springs. Anything you load that needs more than that, your plastic bed won't handle well at all..
    Air bags are a solution with continuous problems, reserved for fanatics with money to burn...
  4. Sep 14, 2011 at 7:37 PM
    ASE_MasterTech
    Monmouth County, NJ
    Sounds like you're mistaking 'rear spring capacity' for 'proper trailer tongue weight'.
    TOO MUCH TRAILER TONGUE WEIGHT!!!
    Stock Tacoma suspensions (with TSB) can easily handle the max tongue weight rated for the stock installed hitch, class 3=500llb (that's less then two fat friends sitting on the tailgate).
    FIX YOUR TRAILER!!
  5. Sep 14, 2011 at 8:25 PM
    Snowman11
    Snowman11 Supreme Ruler
    Snow
    Near Philly
    2011 DCLB TuRD Sport
    5100 Billies
    ...and here I thought tongue weight depended on how many beers you had before selecting your mate.
  6. Sep 15, 2011 at 4:04 AM
    Trudavid2010
    David
    Indiana
    Tix pro dcsb
    None yet
    Well thanks for your opion mastertech but my trailer is a 5 by 8 enclosed v-nose with a gross weight of 2795 pounds so if trailer was fully loaded and loaded tongue heavy the trailer should be well under the Tacoma limits.
  7. Sep 15, 2011 at 8:47 AM
    tacocolin
    tacocolin Well-Known Member
    Colin
    Cloudcroft New Mexico.
    Kevin's (ATO) bad ass rig he built
    Everything Kevin from ATO did on his... and then some. LOL
    Let me know what you think about the tsb when you get it done, I'm buying a 2011 trd 4x4 dc this month, and I will be hauling 2 dirt bikes in the back. Just wondering if I should have it done too. Does it affect susp travel/ flex at all after its done? worse ride? stuff like that.
  8. Sep 15, 2011 at 9:40 AM
    RevHard6
    RevHard6 Well-Known Member
    Nathan
    Sacramento
    11 DC OR 4x4
    I had the TSB on my 08 and liked it. Just traded the 08 in for an 11 and I wanted to get it done the first day I drove it. The three leaf suspension is squishy to me comparatively.
  9. Sep 15, 2011 at 12:37 PM
    Trudavid2010
    David
    Indiana
    Tix pro dcsb
    None yet
    Well I got my truck back this afternoon. The ride seemed to be fine. The dealer also installed my tembren at no charge. We will see tomorrow what difference it makes towing. I can tell a big difference just standing on the hitch. I was shocked that they replaced the whole spring assembly.
  10. Sep 15, 2011 at 12:44 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    When I had mine done it changed the height by 1 " and the ride was just fine. I am glad I did it. 8 months later it still rides up an inch or so. Zero squeeks.
