Leaf Springs 2009
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hot Taco Chick, Feb 5, 2020.
  1. Feb 5, 2020 at 12:57 PM
    Hot Taco Chick
    Hot Taco Chick [OP] Member
    St. Pete, Florida
    09 4WD TRD Sport
    Step Rails, Window Tint, ???
    Hi Everyone - Just found out that my right leaf spring is "cracked" and needs to be replaced (both do). I just had them replaced in August 2016 with the recall. Does this sound normal to any of you?
  2. Feb 5, 2020 at 1:02 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    No it does not take it back to the dealer that you had the recall done with and raise some Kane. They shouldn't fail like that and this is the reason the recall was started anyways.
    Muddinfun and EdgemanVA like this.
  3. Feb 6, 2020 at 6:50 AM
    Hot Taco Chick
    St. Pete, Florida
    09 4WD TRD Sport
    I stopped at Dealer this morning, and they said they have no "authority" to replace and that I would have to file a claim with Corporate.
  4. Feb 6, 2020 at 7:16 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    In as much as i think i remember a potential cocnern with them failing is that after cracking, they could possibly rotate into teh gas tank under whatever conditions, you might be able to get that one through the channels more quickly, or find a local place and get it replaced and work the reimbursement angle. 4 years on a suspension part, replaced by the dealer, i would think gives you an honest shot at it.
  5. Feb 7, 2020 at 9:24 AM
    Hot Taco Chick
    St. Pete, Florida
    09 4WD TRD Sport
    Picked up the truck yesterday and spoke directly with the mechanic.
    The leaf isn't cracked, the shims and bushings are shot. There are actually ZERO shims on the leaf spring, while the other side is fine.
  6. Feb 7, 2020 at 9:31 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Hmmmm that's interesting. Sounds like someone installed them with a bound up bushing causing premature wear.
  7. Feb 7, 2020 at 11:09 AM
    Hot Taco Chick
    St. Pete, Florida
    09 4WD TRD Sport
    Is it possible to replace the shims, or does the whole unit (both sides for balance) need to be replaced?
  8. Feb 7, 2020 at 11:14 AM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    I would look for fresh 3rd gen take offs and call it a day if you're sticking with oem's. They're all over craigslist and fb marketplace for dirt cheap.
