Leaf springs creaking
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scoobarooo, Dec 30, 2014.
  1. Dec 30, 2014 at 3:36 PM
    Scoobarooo
    Scoobarooo [OP] Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    I work at a dealership and had a technician check the noise out with me after work. It seem's like my bushings for the leaf springs are making a creaking noise that's been killing me. I ordered all 6 bushings for my leaf springs. Anyone have any idea how hard of a job this is?
  2. Dec 31, 2014 at 8:55 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    If they're original and rusty it would be reasonably time consuming to replace them, its a pain in the ass to hammer them out… Chances are your leaf springs are worn out and sagging too though… so it would easier to replace them as a whole
  3. Dec 31, 2014 at 11:47 AM
    wingman1961
    wingman1961 Toyota 4X4's since 1982
    Wrightwood, CA
    2019 TRD Off Road DCSB MT
    Bone Stock at the moment
    I realize this is my first post on this forum, been a longtime "lurker" though.. Anyway, a quick fix for your squeaking problem is good old fashion motorcycle chain lube. Been using it for years after the Deavers start the inevitable squeak. I use Bel-Ray. Looks like hell, but it works, and dirt/sand won't stick to it.
  4. Dec 31, 2014 at 12:20 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Which bushings are you replacing? The main eye or the shackle ends?
    Depending on how rusty your truck is...chances are the metals sleeves/bolts are fused together. If all else fails and you can't get them off, you'll need the hacksaw. On the rear, (if I remember correctly) the shackle side plate and bolts are all ONE piece. If you cut that, you'll have to buy a whole new shackle.
    Tell your Technician (aka fellow employee) to do it for you. Don't you get some sort of discount on that sort of thing? :confused:
