Leaf Springs for 2nd Gen RWD 5 Lug
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BaseTaco2wd, Dec 15, 2023.
  1. Dec 15, 2023 at 4:34 AM
    BaseTaco2wd
    BaseTaco2wd [OP] Member
    Stan
    2010 Base model Tacoma 2wd
    I need to find stronger (higher load capacity) leaf springs for a 2nd Gen, regular cab, 6 foot bed tacoma.
    Its base of the base model, RWD, 4 Cylinder 2TR-FE, 5 lug hubs, etc etc
    Ive found some "compatible" options just not confident enough to buy them, not sure what will 100% fit what i need.
    If any of you know a good option for increasing load capacity let me know!
    Even if it means buying a new set of stock springs, and adding a good Add-a-Leaf kit.
    The springs on my truck are 13 years old and im sure that could fatigue it plenty over time,
    I just want to put stuff in my bed without it dropping the rear end so far.
    Im a Welder/ Diesel tech so my bed often gets some heavy stuff thrown in it, like a Kubota motor, ive had a welder in the back, etc etc
    I plan to build a custom bed eventually as well so it will need to handle that weight.
    Dont worry about the lack of motor power, its getting turbocharged as well.
  2. Dec 15, 2023 at 10:30 AM
    Pacificclam
    Pacificclam Well-Known Member
    Carl
    Hawaii
    2010 Tacoma 4x4 Access cab
    6” pro comp lift Kings Coils and Shocks 700lbs Element UCA Atlas Leaf spring kit 17x9 stealth custom series ray 10s -38 33x12.5 toyo open country mt Tom woods driveshaft CSF high performance radiator 4.88 GEARS
    Look into the Atlas leaf spring kits....
  3. Dec 15, 2023 at 10:32 AM
    gstodd
    gstodd Well-Known Member
    2005 2wd base 5-lug
