Leaf springs install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeffBoyardee, Oct 10, 2019.
  1. Oct 11, 2019 at 1:14 PM
    96carboard
    96carboard Well-Known Member
    Even if it was needed for structure, you wouldn't have to replace it. Something like that can be easily weld-filled.
  2. Oct 11, 2019 at 2:38 PM
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    I run grade 8 socket head caps in mine
  3. Oct 12, 2019 at 9:26 AM
    JeffBoyardee
    JeffBoyardee [OP] Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    Perfect. Judging from your work in other threads, I'm good with that.
    I bought an M10 SHCS, 12.9 class. Which is equivalent, or a little better than grade 8, and turned the head down to size on a lathe. Just because I'm a little goofy about keeping everything metric.
    SR-71A likes this.
  4. Oct 13, 2019 at 9:56 AM
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    Fill the hole with a welder and grind it flat. Same thing happened to mine years ago. New center pins and good to go.
  5. Oct 14, 2019 at 11:01 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    I put it back together as is with an M10 socket head screw. Seems to be doing well.
