Leaf springs issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dady83, Dec 5, 2023.
  1. Dec 5, 2023 at 6:14 AM
    Dady83
    Dady83 [OP] Well-Known Member
    2020 Tacoma SR5
    Hi there!! I know this is a known topic. I've been having some squeaky and knocking noise coming from the rear suspension mostly passenger side, I found that the squeaky comes from front bushing,, couldn't find the knocking source yet. (Driveshaft and differential look fine) I replaced the rear shocks couple months ago (bilstein 5100) "not saying that's the cause just giving info".
    Only 20k miles can't believe this is happening on a almost brand new truck. Removing the leaf springs don't think will help specially being almost impossible to remove those bushings w/o damage to grease them. Anyways what can y'all recommend? As always thanks in advance for every input.
  2. Dec 5, 2023 at 7:54 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    There is a TSB for squeaking leaf springs, not sure what years it covers. But they replace the friction pads that go between the leafs.
    EDIT: that TSB is for 16-18. Try using a pressure washer to spray between the leafs. They will build up dirt and squeak
    SH10151 likes this.
  3. Dec 5, 2023 at 8:08 AM
    Dady83
    2020 Tacoma SR5
    Wouldn't that wash out all lubes
  4. Dec 5, 2023 at 8:16 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Knocking? Ever re-torqued your u-bolts?
    Spec is 52 ft/lbs; seems anemic to me
    Before the spec was available, I re-torqued mine to 75 ft-lbs with no ill-effects.
    joba27n likes this.
  5. Dec 5, 2023 at 8:26 AM
    Dady83
    2020 Tacoma SR5
    I did retorque them last weekend, same sh... going on. I'm literally driving an 1800s wagon pulled by horses
  6. Dec 5, 2023 at 8:33 AM
    Mater96
    Mater96 Well-Known Member
    AZ
    2019 Tacoma Offroad 4x4
    Amber DRL retrofit Fox 2.0 coilovers and reservoir shocks
    Taking them out to grease isnt too hard and you wont fuck up the bushings, at least mine came out just fine. However if you are gonna open up the leaf pack to grease em you are gonna wanna order new ubolts and a new center pin. About to do that for my old man emu leafs. As for the sound maybe make sure your spare tire isnt loose?
  7. Dec 5, 2023 at 8:34 AM
    rolled93slc
    Jerry
    Lynchburg VA
    There shouldn't be any lube in them. The TSB about the noise, specifically says do not lube the springs. It caused dirt to collect.
  8. Dec 5, 2023 at 8:44 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Factory bushings do not get lubed. Doing so well just accelerate where extremely fast. The grease will collect debris. It’s a really bad idea.
    The only other caveat would be if the factory bushings have been replaced with polyurethane
    SH10151 likes this.
  9. Dec 5, 2023 at 8:57 AM
    Mater96
    AZ
    Yeah never mind that dirt sticking to the grease thing makes sense. Take it into the dealer if its under warranty for the clunk.
  10. Dec 5, 2023 at 8:58 AM
    Dady83
    2020 Tacoma SR5
    I meant the lube on the other parts, even aiming like a champion with pressure washer is impossible to not wash out everything
  11. Dec 5, 2023 at 8:59 AM
    Dady83
    2020 Tacoma SR5
    Checked it and just fine, I've read a few threads regarding this matter and nothing
  12. Dec 5, 2023 at 9:10 AM
    Clearwater Bill
    Billy
    Largo Florida
  13. Dec 5, 2023 at 9:39 AM
    Dady83
    2020 Tacoma SR5
  14. Dec 5, 2023 at 9:44 AM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    Tiedie likes this.
  15. Dec 5, 2023 at 9:44 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
  16. Dec 5, 2023 at 9:51 AM
    Clearwater Bill
    Billy
    Largo Florida
    You installed a greasable bolt?
    If so, at least you know that point is not your sound source.
  17. Dec 5, 2023 at 1:07 PM
    Dady83
    2020 Tacoma SR5
  18. Dec 5, 2023 at 1:08 PM
    Dady83
    2020 Tacoma SR5
    Not the bolts just the others check out
  19. Dec 5, 2023 at 1:12 PM
    Dady83
    2020 Tacoma SR5
  20. Dec 5, 2023 at 1:14 PM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Gonna throw out a suggestion to make sure your spare tire is tight/seated in the correct position. I've seen countless people chasing clunks and replacing entire suspensions only to realize their spare was moving around.
    embedded rock and Rusty66 like this.
