Leaf springs issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dady83, Dec 5, 2023.
  1. Dec 5, 2023 at 1:17 PM
    Dady83
    Dady83 [OP] Well-Known Member
    2020 Tacoma SR5
    I checked it but thanks for the idea, what I'm doing now help a lot, turning up the radio
    Off Topic Guy[QUOTED] likes this.
  2. Dec 5, 2023 at 1:25 PM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Thats what I do as well. My leaf springs are absolutely smoked..
  3. Dec 5, 2023 at 1:27 PM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    They are made by Dobinsons. They are a pretty reputable brand of aftermarket Toyota suspensions from Australia.
    Tiedie likes this.
  4. Dec 6, 2023 at 9:58 AM
    Dady83
    2020 Tacoma SR5
    Any recommendation for leaf springs stock height replacement
  5. Dec 6, 2023 at 10:03 AM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    Not sure if this helps, but my 2017 leaf springs squeaked quite a bit when the truck was fairly new. I asked the dealer on one of the "free" oil changes and they put in this small black discs ~1" or so between the springs. I have not heard a squeak in a few years. Maybe there is a part number someone can dig up for these "discs?"
  6. Dec 6, 2023 at 10:12 AM
    Dady83
    2020 Tacoma SR5
    All come with those discs, are those specials?? And I know for sure at least one source of noise comes from passenger front bushing
  7. Dec 6, 2023 at 10:17 AM
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    If you're on factory leafs and they are squeaking from the bushings, that's pretty rare. You can replace the bushings.
    If you have poly bushings in the leaf pack, you can get greasable bolts, but they require modification to work right. You need to drill out the poly bushing sleeve to let the grease flow, and you need to change the washer/nut on the end to something actually automotive grade.
    If the noise is from "between" the leafs, they are probably dirty. Jack the truck up (not from the axle) and let the leafs/axle droop as much as possible. Take the wheel off. Power wash, let dry, use a degrease such as purple power, spray all over them, power wash again, let dry. Use a can of fluid film to treat the leafs and between the leafs. Be careful, this is kinda messy, use a cardboard shield as to not spray everywhere. This will quiet them down for a few months.
  8. Dec 6, 2023 at 10:24 AM
    Dady83
    2020 Tacoma SR5
    Thanks for the input, I have stock springs, regarding the greasable bolts I'm a bit skeptical about their strengths, can I use those with stock bushings?? I have no clue what poly bushings are
  9. Dec 6, 2023 at 11:06 AM
    aturk
    Tony
    Charlotte, NC
    No, you would use greasable bolts with poly bushings. Poly bushings require grease to keep quiet.
