Leaf Springs squeak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Barry J, Jun 6, 2009.
  1. Jun 6, 2009 at 7:19 AM
    Barry J
    Barry J [OP] Well-Known Member
    I have a 2008 with Off road package, and have the common leaf spring squeak. It's pretty bad, of course the day I went to the dealership, it was raining, so they just "greased/lubed" the springs.
    Now, a week later, it's just as bad, maybe worse, since I now drive with the windows open.
    I've read all the post about the TSBs and cutting up a bicycle tube and slipping them into the springs.
    But, since it is still under warranty, I would like the dealership to fix it, instead of the tube trick.
    But, being a 2008.....is there a TSB I could refer to when bringing it in???
    The one about the "rough ride" does not mention the 2008 model.
    Can anybody offer some advice??
    Thanks
    Barry
  2. Jun 6, 2009 at 7:25 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    The TSB for the rear leafs should include yours as well. I would look into it a little more because I'm pretty sure theres people on here with 08's that have had the rear TSB done.:cool:
  3. Jun 6, 2009 at 8:10 AM
    Brunes
    Brunes abides.
    Rotorhead
    I don't have any squeak issues- but my guess is they are dirty. The littlest bit of stuff in there will make noises.
    Grease/Lube will only last so long....It will need to be re-done from time to time.
  4. Jun 6, 2009 at 8:37 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    Yeah mine squeak like hell and I've never really taken my off in the mud yet. Gonna have to clean them eventually
  5. Jun 6, 2009 at 8:45 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Well, I have an 06 Sport that has squeaked since day 1. I have gone so far as to take the entire leaf pack apart and grease it with white lithium grease which helped BUT I still get the noise when I hit any roadway that is not perfectly smooth. I have tried the power washing, the WD40, and I even drove up a small creek hoping that the water would work it's way into the springs. Nothing helped. I am just gonna replace'em.:mad:
  6. Jun 6, 2009 at 9:30 AM
    j4x4ar3
    j4x4ar3 Well-Known Member
    Jay
    Austin, TX
    05 DC 4x4 - TRD Off Road - White
    Round Step Bars, Bed Mat, Cargo Bars w/Thules ski and bike attachments, JVC MP3 Head Unit, TRD Cat Back Exhaust, roadmaster active rear suspension, more when $$$ allows
    I have an 05 and only the the past few months have the rear springs started to squeek like crazy. Even getting in the truck makes them squeek. There's no way at this point with 88,000 miles on the truck and being out of warrenty that doing a TSB will fly with Toyota.
    Anyone got direct links to the threads for other solutions? I've already tried grease and no luck. Yes I searched but stuff is all over the board.
  7. Jun 6, 2009 at 12:38 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    My 09 squeaks a lot. I have the TSB done also. But mine is just from going mudding and stuff. I just get the hose and shoot water on them and it makes it better. WD-40 should do the trick you just have to keep re applying it.
  8. Jun 6, 2009 at 12:47 PM
    badguybuster
    Michael
    Another member reminded me earlier that WD40 will attract debris to the area you spray.
  9. Jun 6, 2009 at 12:49 PM
    rmb_crew
    yeah so will any type of lubricant or grease. So either way your going to get dirty and stuff no matter what.
  10. Jun 6, 2009 at 12:53 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    Spray the pads between the leafs with silicone lubricant. (silicone does not attract much dirt)
    Use a flat screwdriver to separate the leafs so that the spray will cover the pads.
  11. Jun 6, 2009 at 1:04 PM
    badguybuster
    Michael
    I actually disassembled my entire leaf pack and grease the damnable things. Most of my noise seems to come from the shackle area. I am debating between replacing the bushings or just replacing the whole thing.
  12. Jun 6, 2009 at 2:05 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    spray em with the pressure washer then get some good lube in there, either triflow or white lithium grease
  13. Jun 6, 2009 at 2:16 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    +1 on silicon, much better than WD40. I use it throughout my house as well, bike chains, ect.
    I have an '08 TRD Off-Road Pre-Runner and got the TSB done no issue, I believe it's actually listed for 08's now as well so it shouldn't be a problem. I've yet to have squeaking but... I only have 21k on the ODO.
  14. Jun 6, 2009 at 5:17 PM
    DDD
    Derek
    Santa Clarita, CA
    It has been about 3 months since my last silicone spray and the squeak has not come back yet.
  15. Jun 6, 2009 at 9:47 PM
    chrisdculp1@Yahoo.com
    chrisdculp1@Yahoo.com Big Island
    Teahupoo
    Big Island, Hawaii
    07 tacoma TRD
    had new leafs put on by the dealer and it made a huge differance. It was all cover buy the TSB
  16. Jun 28, 2009 at 4:53 PM
    Barry J
    But, isn't the TSB for "bottoming out" and not for squeaks???? Mine squeaks but I have not noticed any bottoming out yet, but I have yet to haul anything heavy.
    Will the stealership still do the TSB???
    What should I tell them???
    Thanks
    Barry
  17. Jun 28, 2009 at 5:24 PM
    rmb_crew
    I found out that using tire shine works great for making the squekyness go away.
  18. Jun 28, 2009 at 5:27 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    That's what I do. Works like a charm.:)
    Charlot likes this.
  19. Jun 28, 2009 at 5:35 PM
    awwmann
    awwmann Well-Known Member
    pat
    staten island new york/ redbank nj
    2015 4x4 double cab trd sport
    bilstein 5100/ 265/70/17
    mine was squeaking from day 1 went to the dealer about 6 months ago theres a tsb for squeaking they put some kind of pads between the leafs mine havnt squeaked since its in the body shop when it comes out ill try to get a pick of the pads
  20. Jun 28, 2009 at 5:47 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    I'm in the same boat as you................all my driving is on frwy and paved streets..............welcome to LA............anyway I know I get some road dust but not that much.............I had a 2000 trd prerunner that never went in the dirt,and was driven just like my driving habits are now and it never made a sound................what did Toyota change in 2005 that is making these trucks sqeak so much?
