Leaf Springs that will give me 3" lift on a double cab?
Discussion in 'Suspension' started by Tacorriendo, May 7, 2014.
  1. May 7, 2014 at 9:24 AM
    Tacorriendo
    Tacorriendo [OP] Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    I searched the posts and have not been able to find If anyone has bought leaf springs that gives you 3"lift and avoid the blocks? Also would like to know if there are ones that offer equal or better ride that OR stock leafs?
    Thanks and sorry if this question has been asked before, but I have missed it.:eek:
  2. May 7, 2014 at 9:31 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  3. May 7, 2014 at 10:36 AM
    Tacorriendo
    Fred
    Texas
    Thanks OZ, but I forgot to mention that I also want to avoid the AAL. My bad! So far the only ones I have seen online, are the SkyJackers, but have no data as to how they ride or exactly how much lift is expected. Only says on their website that it depends on the trim of the truck.
  4. May 7, 2014 at 10:51 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Expos after they sag an inch :eek:
    From Headstrong's website: "These extra leafs are made specifically for the OME Dakar leaf packs and will raise the bed of your truck an additional 0.75"-1". With the AALs installed the spring rate is increased providing additional support for those carrying heavier loads on a regular basis."Two extra leafs made specifically for the CS047 leaf spring set that raises the spring height by 15mm and increases the spring rate for increased heavy load stability. - See more at:
  5. May 7, 2014 at 10:52 AM
    OZ-T
    Peter North
    British Columbia
    the d29xl OME AAL is just an additional leaf that is designed to fit into the Dakar pack
    EDIT : Geekhouse beat me to it
  6. May 7, 2014 at 11:29 AM
    Tacorriendo
    Fred
    Texas
    Thanks guys, but I don't really need the extra payload capacity cause I already have air bags for that. What I'm looking for, is a soft ride equal or better than stock but 3" higher than stock. I appreciate your responses.
  7. May 7, 2014 at 1:26 PM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    Well, from your first post I was going to say AAL and Airbags with a spacer and cup, but this post states you have air bags and you want 3" lift with no change in ride from stock.
    This tells me that you want a block.
    I do not recommend a block, but I will tell you to add a 2" spacer below your airbag.
    Most everyone here who has lifted their truck AND hauls a half ton from time to time will tell you that the higher center of gravity requires a little stiffer spring, aaaaand that an AAL is the most cost effective way to get it.
    My own recommendation is that if you will be hauling or towing frequently that you use at least a 2" or 50mm rear shock so you don't kill anyone.
    Enjoy!
    unsubbed....
  8. May 7, 2014 at 2:50 PM
    Tacorriendo
    Fred
    Texas
    Thanks for the input, but as I mentioned, I don't want blocks. Also I already have the bilsteins 5100's for a 3-4" lift installed(different part #). So the only thing I'm lacking per say, is a set of leaf springs with the same spring ratio as the OEM OR but with a "deeper arc" to give me 3" of lift by themselves with no extra "add-ons". Once I find them and install them, then I would have to get the air bag cups as to not obstruct articulation. Don't know if I'm being clear?
  9. May 8, 2014 at 8:02 PM
    TaKoToy
    TaKoToy Well-Known Member
    Robbie
    Prince George VA
    2013 4x4 OffRoad, 2020 cement DCLB OR
    Mostly stock
  10. May 8, 2014 at 8:15 PM
    Luke01
    Luke01 Well-Known Member
    Luke
    Dallas, TX
    2012 Tacoma DCSB MGM lifted dented and armored
    Grillcraft Grill, Leer 100q top, 5100's on four corners, OME 885x up front, OME Dakars with add a leaf in rear, Lighting, a mix of Rigid and Chinese LED's, US Off Road hidden winch front bumper, SOS offroad conceprs skids, and rear bumper with swing out
    So you want stock ride quality, with the ability to tow, 3" of lift, and you don't want to add a leaf to an OME Dakar spring pack?
  11. May 13, 2014 at 6:22 PM
    Tacorriendo
    Fred
    Texas
    Yes. I already have the air bags for towing. All I need, is stock ride or better, but three inches higher with no blocks or AAL.
  12. May 13, 2014 at 6:23 PM
    OZ-T
    Peter North
    British Columbia
    Good luck
  13. May 13, 2014 at 7:48 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    A 3 leaf aal and a 1 inch block could get you close to 3" and probably be softer than dakars or expos.
  14. May 18, 2014 at 8:08 AM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    Dakars will get you 2 1/2 if your leafs are still good, I got full 3"+ because my leafs were sagging. You can get the AAL for an additional 1" or retain lift with a cap...
