Leaf springs with built in lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by howeller14, Mar 30, 2021.
  1. Mar 30, 2021 at 7:54 PM
    howeller14
    howeller14 [OP] New Member
    Alex
    White 2012 Tacoma Access Cab 4x4
    So, I need to replace my leaf springs on my 2012 tacoma, and have been wanting to do a 3 in spacer lift and level for a while. Figured might as well do both at the same time.
    First of all, how hard is it to replace leaf springs, and second, are there ones I can get that would already come with a 2 inch (rear) lift? I’ll get 3 inch front spacers as well to complete the lift if so.
    May also get 1.5 inch wheel spacers at the same time, anyone have good or bad things to say about rough country’s spacers?
    And please give me any recommendations on brands for leaf springs, wheel spacers, or front lift kit spacers.
    Thanks!
  2. Mar 30, 2021 at 8:04 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Sounds like you like spacers. Welcome to TW and good luck with your truck.
    blu92in99 and Jojee117 like this.
  3. Mar 30, 2021 at 8:40 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes, they do make leaf packs that raise the rear.
    Here is one example As for the install, YouTube will be your best source for that.
    It isn’t too hard. If you can manage to get spacer in, you can probably do the leaf packs.
    BTW, you might want to read up on what else you may need when going 2.5+ of lift.
    Specially Upper Control Arms if you want any type of decent alignment and no risk of rubbing the UCA.
    blu92in99 and Jimmyh like this.
  4. Mar 31, 2021 at 9:57 AM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    spacers will get the job done. I rocked that when i just bought the truck. you can maybe find some "take-offs" leaf springs from a 2016-2021 tacoma, in case yours are sagging to much. Bolts right in.
    or you can buy a leaf pack.
    better choice and will last longer. buy once, cry once.
