leaf springs
Discussion in '1st Gen. Tacomas (1995-2004)' started by mudjunkie, Sep 23, 2008.
  1. Sep 23, 2008 at 2:57 PM
    mudjunkie
    mudjunkie [OP] Well-Known Member
    clearwater fl
    96 tacoma sx l
    header,short rack and pinion, heavy duty shocks, grill guard, flowmaster exhaust,pacesetter header without catalytic converter, one 10 inch xant sub with a mtx amp, off road lights,diamondplate tool box,rhinolined inside cab,ngk plugwires.
    found a set of leaf springs off an 89 toyota 4x4 wondering if they will fit on my 96 there 49 inches from bolt to bolt mine asre 51 inches but i did notice that there may be some play in the shackles just enough to squeez them on ny opinion would be great
  2. Sep 23, 2008 at 4:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Short answer, NO. You can "Make" them fit, but would you? They wont flex as much, with the added weight, they will ride horribly.
  3. Sep 23, 2008 at 7:12 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Exactly what Chris said...
    Shackle *play* (as you call it) isn't something to take lightly. That play needs to be there for proper suspension movement & strength. It's a technical science to the design. Just don't ask me how to explain it, cuz I couldn't.
    You need to find the proper length leaf springs regardless of what the shackles are doing.
  4. Sep 23, 2008 at 9:14 PM
    mudjunkie
    clearwater fl
    96 tacoma sx l
    thanks guys i was hoping they would just plop right in you know i guesss ill put up the cash and just do it right
