Leaf Springs
Discussion in 'Canada' started by vanzigler, Aug 21, 2011.
  1. Aug 21, 2011 at 5:04 PM
    vanzigler
    vanzigler [OP] Active Member
    Van
    alberta
    05 tacoma v6 sr5 TRD sport
    aFe Cold Air Intake si with 5R filter, Flowmaster Dual Exhaust, OME 885 Dakar suspension kit, Hella Driving lights, VVME 35W HID headlights, VVME 55W HID Fog lights, 2" BORA Wheel Spacers, Throttle Body Spacer
    Hi guys my 2005 Tacoma's rear end is sagging, my local dealership told me that there is a TSB #3055 on it. MY question is do I have to change the front as well? Thanks!
  2. Aug 21, 2011 at 5:06 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    You're able to get the TSB done on an '05 ?
  3. Aug 21, 2011 at 5:15 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    I think that started in 09...?
  4. Aug 21, 2011 at 5:21 PM
    OZ-T
    Peter North
    British Columbia
    Canadian trucks have had 4 leaf packs , or the TSB pack since 2007 .
    I'm suprised he qualifies for a TSB outside of the three year warranty
  5. Aug 21, 2011 at 5:25 PM
    BlueTaco07
    Cody
    Looking
    Yeah the 3 year covers back to 09 right? And the 60k mile warrenty hes probably way past that as well.
  6. Aug 21, 2011 at 5:25 PM
    BlueTaco07
    Cody
    Looking
    OP the fronts fine unless your trying to lift it.
  7. Aug 24, 2011 at 11:20 AM
    vanzigler
    Van
    alberta
    hey guys, i don't qualify for the TSB #3055, but my truck is included in that bulletin. I'm not trying to lift it, I just want the back to be higher than the front. I've heard from a local shop that add-a-leaf isn't for long term, so OME would be the way to go. But he also said that he would recommend upgrading the front as well. But I'm not trying to lift the truck. Any suggestions?
  8. Aug 24, 2011 at 12:38 PM
    OZ-T
    Peter North
    British Columbia
    The OME rear leaf pack ( Dakars ) will lift your rear 2 3/4 - 3" . If you are not intending on lifting your truck , this is not the route to take .
  9. Aug 24, 2011 at 2:10 PM
    vanzigler
    Van
    alberta
    Yeah I'm not trying to lift the truck, All I wanna do is to lift the rear back to stock height or higher. What are my options? Add-A-Leaf?
  10. Aug 25, 2011 at 8:41 AM
    OZ-T
    Peter North
    British Columbia
    Look into a progressive AAL
  11. Aug 28, 2011 at 5:11 PM
    elwood
    elwood "Really, how hard can it be?" Jeremy Clarkson
    Neal
    ont, canada
    2007 SR5 4x4 LB
    K/N cold air intake, leer cap, running boards, nose gaurd,E brake control, mud flap cut, suspension tsb, Rear diff breather mod,Factory Fog lights, Factory front diff cover
    I made my own from another tsb pack. Maybe look for a used tsb pack in a wrecker. All depends what you want out of the truck and what you will use it for and how much $ you want to lay out.
    Good Luck :)
  12. Sep 10, 2011 at 6:18 PM
    vanzigler
    Van
    alberta
    I can't put the AAL in the stock springs cuz they're flat and it's gonna be hard to put them in there. Even if I was able to put the AAL in there, they would flatten again in about 6 months! Any other suggestions?
