Leaf Springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beeftaco99, Jun 30, 2020.
  1. Jun 30, 2020 at 7:10 AM
    Beeftaco99
    Beeftaco99 [OP] Active Member
    South East, PA
    06 DCSB SR5
    I’m between General HD’s and the Deaver J66 springs. Can anyone share some more experience if you have these springs? I do not really want to add height the the rear. I can live with about an 1” increase. My current springs were replaced under the TSB a few years back but are once again shot. Bottoming our with bearly any load in the bed.
  2. Jun 30, 2020 at 7:12 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    If your not carrying weight but want something tough go w/ the Dakar Mediums. I have the HD's with a cap, fridge, RTT, tools, etc etc etc and it holds the weight and rides nice.
  3. Jun 30, 2020 at 7:18 AM
    Beeftaco99
    South East, PA
    06 DCSB SR5
    @diabetiktaco I guess I should have mentioned I did not want to add much lift in the rear. How much lift did it give you?
  4. Jun 30, 2020 at 7:21 AM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    The HD's gave me quite a bit. I don't know exactly what it was I guess my truck is like 2.75"
  5. Jun 30, 2020 at 7:26 AM
    Beeftaco99
    South East, PA
    06 DCSB SR5
    Ok yea I’m not looking to go that high I have a 2” lift in the front. I’m only a little bit squatted rn. Looking to maybe go an 1” in the rear. With brand new springs I might even be level, my currents springs are pretty sagged.
  6. Jun 30, 2020 at 8:22 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    what about adding airbags to your stock leafs?
  7. Jun 30, 2020 at 9:54 AM
    Beeftaco99
    South East, PA
    06 DCSB SR5
    Do you run them? I haven’t really thought about them. I feel like it’s just a bandaid like the springs are just bad.
  8. Jun 30, 2020 at 12:18 PM
    Hikerbox
    Hikerbox Well-Known Member
    2015 SR5 Access Cab
    Pretty sure the deavers will add 2-3" as well. Have you looked at the Icons? They let you take out leafs for less spring rate/lift.
  9. Jun 30, 2020 at 12:24 PM
    nd4spdbh
    SoCal
    Airbags or sumo springs Its about the only option to add better load handling without lifting. Pops had them on his 2016 taco and they worked great.
  10. Jun 30, 2020 at 1:42 PM
    Beeftaco99
    South East, PA
    06 DCSB SR5
    Were his springs shot?
  11. Jun 30, 2020 at 2:29 PM
    minidi2
    minidi2 Well-Known Member
    Marcus
    2015 Toyota Tacoma TRD Pro
    Supercharger, Heated Seats, Modified Cell Holder,
    If anyone that is running the air bags... I would like to know your input or review as I am contemplating on bags vs leafs
  12. Jun 30, 2020 at 3:12 PM
    cwadej
    cwadej Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    I have airbags because I occasionally add RTT and a bunch of other stuff, plus being able to inflate one helps level when camped. Usually have just a few psi in them
    They replace your bumpstops.
    I just replaced my worn out 2011 TSB packs (with Headstrong 3 aal) with Icon. Worn out springs rode on the airbags, stiff ride with no weight. For the money, the Icon RXT Packs are great for adjustable height. Look into them.
    Beeftaco99[OP] likes this.
  13. Mar 17, 2021 at 8:11 AM
    Pinion
    Pinion Well-Known Member
    Drew
    Brookings Oregon
    2020 DCSB limited 4x4
