Leaf springs
Discussion in '1st Gen. Tacomas (1995-2004)' started by Chadsterman, Jul 5, 2020.
  1. Jul 5, 2020 at 9:22 AM
    Chadsterman
    Chadsterman [OP] New Member
    Chad
    04 Tacoma Double Cab
    Looking for recommendations for replacement leaf springs. No mod, just OEM. Bertha is rolling passed 260k on the little mile counter. Thinking she might need some new ones.
    LearningToFly and Black DOG Lila like this.
  2. Jul 5, 2020 at 9:26 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
  3. Jul 5, 2020 at 9:48 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
    The OEM leaf springs are pretty expensive from what I read, like $400-500 per spring. General Spring seems to be be the brand recommended for people wanting an OE-spec replacement.
    Kwikvette likes this.
  4. Jul 5, 2020 at 9:51 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    As mentioned above, General Springs with new u bolts and shackle bushings.
  5. Jul 5, 2020 at 11:27 AM
    underaroof
    underaroof ember
    Eastern Sierra
    2004 Xtracab 4x4 V6 TRD
    My General Springs are fine after a year, pretty much a stock replacement. It'll lift it a bit from you consider normal, since your OEM springs are likely sagging.
  6. Jul 6, 2020 at 6:18 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I just installed new General Springs on one of my trucks. I bought the OEM replacement level. Truck is not on the road at present, but my impressions of the company, the prices, and the quality/fit of the parts is very good. Fingers crossed on no squeaking.
    My only bit of negative feedback to them was the u-bolts were not bent to a true 90 degree angle and would not fit through the bracket without a bit of work. I ended up using a large c clamp to pull them close enough to get through the bracket. Tried putting them in a vise, but they just rebounded to original shape when removed. Good steel apparently, just a bit too wide an angle.
  7. Jul 6, 2020 at 6:29 AM
    LearningToFly
    LearningToFly Well-Known Member
    Northeast Alabama
    2004 Double Cab
    Are they completely flat on the truck or do they have some positive arch? Mine have about 160k on them and they look pretty much completely flat.
  8. Jul 7, 2020 at 1:20 PM
    underaroof
    underaroof ember
    Eastern Sierra
    They flattened out the day I put them on, I think that's just how the 'standard' springs on these trucks are.
    LearningToFly[QUOTED] likes this.
  9. Jul 17, 2020 at 7:47 PM
    Chadsterman
    Chad
    Yeah, I would say they are about flat across.
    The bounce over bumps is what has me thinking on changing them. The shocks aren't but a couple of years old.
  10. Jul 18, 2020 at 1:52 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I also vote for General Spring they are my go to spring dealer .
    I do source my Hardware local in case a problem of something not fitting
